Author Topic: firewall forward frame design  (Read 20192 times)
Offline Jonny Hotnuts
Re: firewall forward frame design
« Reply #30 on: October 24, 2007, 08:25:26 PM »
What is the point in having a MS class if you can only stretch the front to 130” and change the motor manufacture?
Really takes the “Modified” of MS.
Too bad I could not add a back seat and enter in CC or maybe a new class called Comp Sports!!!
(I think that this rule affecting only MS and not CC is BS. To me MS is the CC of the sports car and the rules basically parallel, a rule such as this should affect both.)
jonny_hotnuts@hotmail.com
*Andres Segovia
« Reply #31 on: October 24, 2007, 08:57:48 PM »
Personally I don't think you are gaining that much by trying to make the very front so narrow.  You still have the frontal area as the widest part of the car. Go back to what Tom and I talked to you about making it similar to the Blowfish.  Since you can tuck each side in 3 inches and you can run a narrower tire than stock (remember you are measuring from the tire center to center) you should be able to close the wheel openings if you want.  You don't need much of a turn radius there.  Go out on the highway with your street car and turn the wheel one inch and see what a drastic change of direction that is.
Don't get discouraged, you will be fine, and remember you set a record where there was no record before, so everyone who tries to go after your record will have to play by the same rules,
« Last Edit: October 24, 2007, 09:19:30 PM by Sumner »
Offline JackD
  • NOBODY'S FOOL
« Reply #32 on: October 24, 2007, 09:05:56 PM »
MS, CC, and MR front ends are all in the same boat.
One little navigation error will really get you off course.
Now after being lost at sea it is tough to get back. :wink:
Offline sockjohn
« Reply #33 on: October 24, 2007, 09:45:48 PM »
I think this is dead on.  If you look at an "ideal" nose shape, it's not a pointy triangle :)
Offline interested bystander
« Reply #34 on: October 24, 2007, 11:12:16 PM »
Maybe a "pointy triangle' isn't for landspeed racing, but I'd confirm that with Area 51 folks, 2 B sure!
5 mph in pit area (clothed)
« Reply #35 on: October 25, 2007, 07:20:07 PM »
Smaller front end = reduction of wetted surface resulting in better Cd.
Smaller front end = ability to have smoother transition to the stock body and maintain a linear flow without separation of the boundary layer.
Smaller front end cross sectional area = improvement in CP and better lateral stability.
Only thing a minimum track rule will do is make my car longer.
*Andres Segovia
Offline Unkl Ian
« Reply #36 on: October 26, 2007, 10:08:41 AM »
How does a narrow front end improve Center of Pressure ?
I guess the answer is "a Secret" .
« Reply #37 on: October 26, 2007, 12:30:32 PM »
More narrow will not but smaller side surface area will.
*Andres Segovia
« Reply #38 on: October 26, 2007, 08:07:32 PM »
Mr Hotnuts has had to re-explain himself. The key word a couple of posts back was "Wetted Area"- I recommend Prof. Katz book for explanation of terms- it reads pretty easy. In fact Paul Glessner uses it in his aerodynamic seminars as the text.
That comment re: wetted area got me thinkin'...good thing at my age ..but OF COURSE it does and therefore enhances the CP/CG correct relationship. Makes the back half more of a fin because it leaves more body bulk back there..
"It's just a box with five strings and a neck" - Julian Bream
« Reply #39 on: October 26, 2007, 08:48:21 PM »
Julian is a bird of a diffrent feather....so old now, doent play anymore.
Still likes to have a few beers at the local pub from what I hear.
Not sure what he was meaning with the quote.....guitars have 6 strings....maybe he also had a banjo laying around we didnt know about.
I learned alot from Bream......
I transcribed his version of the rondo in Am by Dionisio Aguado (considered by some to be his hallmark piece and what I usually finish a concert with).
Here is Bream and my transcription:
http://www.classtab.org/da_r_am.txt
http://youtube.com/watch?v=k_ItONyor04
*Andres Segovia
« Reply #40 on: October 26, 2007, 09:19:09 PM »
havin' fun with you Hotnuts as I hope you know- great that we can all come together and yet have many different "passions"
I'm about to out on the patio and turn on KUSC  (LA's ONLY classical station, now  and have my evening beer>-Thanks for the references.-They don't play enough of your -type stuff.
got two-three more sign-offs after Bream- hope you'll enjoy!
« Reply #41 on: October 26, 2007, 09:34:04 PM »
P.S to the last- Should have quoted Peabody, not Bream-blew my cover- I'm a listener, NOT a PLAYER! will pass your transcription on, though.
