Thanks for all the kind words. We had 800hp to run 213mph and I'm thinking another 1000rwhp should do it. We are going to keep it a small block. I saw many cars that had 671 's sticking out of the hood in 69 camaros and they were in impound alot.......a magazineen car especially. I really want those guys! we will bring several different front ends and would like to run several different classes. My shop builds Mustangs, I can't use a Camaro body even if it's better aerodynamically. I guess we will see how far it we can go with the 95 Stang chassis. I have seen plenty of drag pieces but nothing geared to the salt flats.......that may be telling me something but I'm hard headed. Any help would be appreciated. What is the stock Chassis record?
SteveD
in Houston
Let's play with some numbers and remember that these are just numbers based on a bunch of guesses.
Above you mention 800 HP to run 213 and below that talk about 1000 RWHP. I'm assuming the 800 wasn't RWHP.
Using the spreadsheets on my site:
http://purplesagetradingpost.com/sumner/bvillecar/bville-spreadsheet-index.htmlIf I say your car currently has a Cd of .35 and a frontal area (at it's widest point) of 27 sq. ft. I figure (using the Drag Force-HP-Thrust-Weight spreadsheet) that it would take 623 RWHP to run 213 mph. That might be realistic as that is 79% of what is your crank HP if the 800 was crank HP. Also you would need 2200 lbs. down-force on the rear axle for traction for a .5 coefficient of traction for the salt.
Now using those Cd and Area numbers to run 300 mph with the car unchanged would take 1740 RWHP and 4400 lbs. on the rear axle for a .5 coefficient of traction for the salt.
Now let's say you can lower the Cd to .30.
To run the 213 mph you would need 534 RWHP and 1900 lbs. on the rear axle.
To run 300 mph you would need 1492 RWHP and 3700 lbs. on the rear axle.
Some things to consider here and you might already be aware of them.
The importance of and relationship of the Center of Gravity ( CG ) and Center of Pressure ( CP ) to one another:
http://purplesagetradingpost.com/sumner/bvillecar/bville%20-%20LSR%20Thoughts-4.htmlThrust and it's relation to weight (down force) on the drive wheels:
http://purplesagetradingpost.com/sumner/bvillecar/bville%20-%20LSR%20Thoughts-3.htmlGearing has to be dead on at these speeds with a realistic gear that will just run the required speed at the rpm where you have the HP to achieve that speed:
http://purplesagetradingpost.com/sumner/bvillecar/bville%20-%20LSR%20Thoughts-5.html...........and like Mike said a dozen other things that have to be right on when you are shooting for a goal like you have set. I don't mean to be pessimistic, but a 5 year plan would probably be a realistic minimum for the goal of running 300 mph in almost any type car. You start running in the mid 200's and everything has to be right, track, car, crew, weather, time of day you run, etc..
Mike let loose with some really invaluable info in his post. Thanks Mike, I almost always learn something from what you have to say.
Good luck and if I can help let me know (and I'm a Chevy guy),
