Please suggest specific modifications to this proposed rule change or correct errors.
7.F.4 Front Fender
All fenders must be . . .
Front fenders may not project forward of the front edge of the wheel rim. Front fenders may not be lower than a horizontal line drawn through the front axle centerline.
7.F.11 Class “M” modified production frame class, Streamlining:
1. Streamlining is defined as any devices or objects which have the apparent purpose of directing, limiting, or controlling airflow around the machine or rider.
2. No streamlining is permitted forward of the rider other than a front fender.
3. Streamlining is permitted behind the rider.
a. OEM bodywork for the specific production model are allowed. Bodywork shall be mounted in a conventional manner and all bodywork pieces must be mounted in their original relationship to each other. Replacement non-OEM bodywork must be an exact replica of the OEM parts. Documentation to verify conformation of non-OEM parts to OEM parts must be made available to the inspector by the competitor.
b. The following rules apply to motorcycles not using OEM components (or replicas of those components), or using bodywork on a production model that was not originally equipped with those parts.
i. No portion may extend below the top most portion of the wheel rim behind the centerline of the rear axle.
ii. No portion may extend beyond the rear edge of the rear tire.
iii. No portion may be higher than 36 inches above the ground with the rider seated on the bike.
iv. No portion may interfere with egress. Pockets or recesses that may trap a portion of the body are not allowed. This rule takes precedence over all others.
v. It must be possible to see the rider completely from either side at the level of the handlebars and directly above the helmet. If removal of the bodywork would allow any additional portion of the body to be visible from either side at the level of the handlebars and directly above the helmet it is not allowed.
vi. It is forbidden to use any transparent material to avoid the application of these rules.
vii. Bodywork must have a minimum of three (3) separate mounting points.
7.F.12 class “MPS” modified production frame, partial streamlining class, Streamlining:
1. MPS allows streamlining forward of the rider.
2. In addition to the rules in 7.F.11, these rules apply to MPS:
a. It must be possible to see the rider completely from either side at the level of the handlebars and directly above the helmet except for the hands and forearms. If removal of the bodywork would allow any additional portion of the body to be visible from either side at the level of the handlebars and directly above the helmet except for the hands and forearms it is not allowed.
b. No portion may extend below the top most portion of the front wheel rim ahead of the centerline of the front axle.
c. No portion may extend forward of the front edge of the front wheel rim.
7.G.11 Class “A” special construction frame class, Streamlining:
See section 7.F.11.
In addition to those rules, these modifications are allowed:
1. No portion of the rear bodywork may extend more than 8 inches beyond the rear edge of the rear tire.
2. No portion of the rear bodywork may be higher than 40 inches above the ground with the rider seated on the bike.
7.G.12 class “APS” special construction frame, partial streamlining class, Streamlining:
See 7.F.12
