Great project. After looking at your engine placement, How much "stuff" are you going to mount on the front (now rear facing) engine.
There are a lot of items, inclulding but not limited to: balencer, water lines (possible pump) possible drive for fuel pump, dry sump, alternator, ecavuation system. etc all at the drivers feet. Maybe your not planning on much but it seems a little tight. You wil definatley need another "bulkhead" or other sustantial shielding for belts and the like. Also I couldn't find a wheel base listed.........Good Luck. JD
