Just updated myself on your progress, top stuff!
You said that you still don't know what plane your tank came from. I reckon it should be fairly easy to find out and interesting too. On our tank we found a stamp with a number as well as the remnants of a painted plane number and from that we gained a huge amount of info from the net from the boffins there. Our plane appears to have had active service over Russia and was chased out by Mig17s. Exciting stuff.
If you can find some numbers or something and put them up here I am pretty sure I could find something for you...
"Today we started on the rear axle. We chose spindles and brakes from a caravan. Several reasons for this. 1, The spindles are flat backed . 2, you get your choice of drum or disc brakes and 3, they are plentiful and cheap".We had the same plan for our front spindles (trailer hubs) but found after a while that it was a weak point as they turned out to be not quite true! By putting the wheels on and rotating against a known point we found that they oscillated in and out by quite a few millimeters. Fine for a trailer or caravan maybe but not good if going the speeds you intend to.
Yours may be fine but worth a check!
"Sometimes I feel shitty about posting updates every week. Especially like today. The work went slow, the pics are lousy, and not much to show for a long days work. I promised myself I'd keep posting regardless of the outcome so here goes."Rest assured we love it!!! Even just looking around your weird shed is a hoot. What on earth is the Famingo Cafe? And who is the pedal car nut that has 30 of them stacked in storage?
"We chose Goodyear frontrunners cause we know they can handle the speed, they have no tread edges to catch on a spinout, and they're light. I was bitching about the halfassed paint job they did on the letters, and then realized they didn't paint two of the tires at all! Just as well, I suppose if that's the best they can do."No it's not the best they can do! It is appalling workmanship and lack of care. Especially when they are so expensive. To not even paint them is even worse. I've said it before and I'll say it again, "Shame on you tyre makers".
Check out this thread for some cool old school tyres where quality counted!
http://www.jalopyjournal.com/forum/showthread.php?t=239766At least by not painting them you have a clean start to paint them well yourself!
Keep up the good work.
rH+
