Author Topic: Marlo Treit's Liner  (Read 251616 times)
Re: Marlo Treit's Liner
« Reply #330 on: July 17, 2009, 12:52:36 PM »
I'm sorry that I haven't posted for a while.
I will give some relief from body panels. That next to last panel has become a major problem.
The connection between the blowers and the collector box on top of the manifold is being addressed. Each collector has provisions
for 3 burst panels. The top of the body had a built in "discharge area" that coincides with the position of the burst plates.
There is a removable crossmember directly in the path of the connection from the discharge to the input side. The route will be altered.
I'll post 4 images and add some more soon.
« Reply #331 on: July 17, 2009, 01:28:24 PM »
I tried 12 times to post 2 fotos. Sorry, they will never get posted.
Here was the message that goes with them but the fotos will never appear.
After Marlo had a blower sneeze on the lakester and found only shrapnel from the aluminum collector, he built these out of 3/8" and 1/2"
steel. Hume told Marlo that if he balloons these body panels, just to head home because he's not going to rebuild them.
Do u suppose that all that did is make the explosion louder if these let loose?
H E L L for stout................H E L L  for loud !!
« Reply #332 on: July 17, 2009, 11:02:19 PM »
Please excuse me. I'll try to solve the problem. I shouldn't toss the bocquet before the bride says NO.
I'll figure out a way to show the fotos. Even the Webmaster of Landracing.Com has experienced the same problem.
I'll figure out a way.
Give me some time.
THANX
« Reply #333 on: July 17, 2009, 11:04:45 PM »
13th try. The above post explains the fotos.
« Reply #334 on: July 20, 2009, 12:52:43 PM »
I just took a chance to see if I could get connected.
Offline bobc
    • South Mt. Web Design
« Reply #335 on: July 25, 2009, 05:07:35 PM »
test post 8
Web Elf
Offline bobc
« Reply #336 on: July 25, 2009, 05:08:00 PM »
test post 9
Web Elf
Offline bobc
« Reply #337 on: July 25, 2009, 05:08:28 PM »
test post 10
Web Elf
Offline bobc
« Reply #338 on: July 25, 2009, 05:08:50 PM »
test post 11
Web Elf
Offline bobc
« Reply #339 on: July 25, 2009, 05:09:37 PM »
test post 12
Web Elf
Offline bobc
« Reply #340 on: July 25, 2009, 05:10:51 PM »
test post 13
Web Elf
Offline bobc
« Reply #341 on: July 25, 2009, 05:11:31 PM »
test post 14
Web Elf
Offline bobc
« Reply #342 on: July 25, 2009, 05:12:11 PM »
test post 15
Web Elf
Offline bobc
« Reply #343 on: July 25, 2009, 05:14:16 PM »
test post 16
Web Elf
Offline bobc
« Reply #344 on: July 25, 2009, 05:15:36 PM »
test post 17
Web Elf
