Author Topic: Getting ready for Bonneville(rebuild)  (Read 1897890 times)
0 Members and 10 Guests are viewing this topic.
« Reply #930 on: March 06, 2010, 01:14:52 AM »
  I'm also trying to decide on a water injection system how much water to inject, and were to mount the tank.
  Looks like about 1/2 gal min and 250 psi pump and a one gal tank and one of the simpler kits, or we might make our own
 package up.
Offline bvillercr
« Reply #931 on: March 07, 2010, 12:18:01 AM »
Got the engine and blower system out, now we need to do a complete tear down.  The clutch, flywheel, crank, cam....  You get the picture.  Should have it all back together before the second week of May. :mrgreen:
« Reply #932 on: March 07, 2010, 01:20:27 PM »
John and Troy,
Any thoughts of trying to make Elmo in May?
« Reply #933 on: March 07, 2010, 01:42:37 PM »
John and Troy,
 Hi Rex... Yes, now that Elmo has been flooded were planning on running. Troy implied that the engine needed to be completely torn down but the only thing left in the engine is the crank and cam. The heads are at the head shop and the only reason we pulled the engine is to check the balance of the crank and flywheel assembly.
« Reply #934 on: March 07, 2010, 11:38:03 PM »
John,
Are you planning to put your car on the dyno again? If so let me know as I would really like to watch!
Offline bvillercr
« Reply #935 on: March 07, 2010, 11:57:09 PM »
Rex we will have it on the dyno before the May meet, we'll keep you posted. :cheers:
Offline bvillercr
« Reply #936 on: March 11, 2010, 03:15:24 PM »
Here's a couple pictures of our engine compartment getting cleared out.
Just a picture of our two motors, the A we are currently running on the right and our AA on the left.
« Reply #937 on: March 11, 2010, 06:37:09 PM »
If u use the AA engine, does it have to go to meetings?
Offline landsendlynda
« Reply #938 on: March 11, 2010, 08:24:14 PM »
Freud,
Only if it becomes an oilaholic!
Lynda
Volunteer roadblock at Land's End! Yes, you need your stinkin badge! I'm your Dream Keeper, I protect your dream on the asphalt so you can chase your dream on the salt!
« Reply #939 on: March 11, 2010, 09:39:51 PM »
    It's been sentenced to meetings at El Mirage and Bville busting dirt and salt :-P
             JL222 :cheers:
Offline GH
« Reply #940 on: March 12, 2010, 09:50:17 AM »
John and Troy, you guys should think about going to coil packs and crank trigger ignition instead of the distributor. Your geeks can run it through the computer, that's a great system. We put that on the straight 8 Buick, it's rock solid, no movement at the balancer with the timing light.
Offline bvillercr
« Reply #941 on: March 12, 2010, 10:08:13 AM »
Gary the distributor acts only as a source to deliver spark.  We do have a crank sensor and it runs off of our FAST unit.  A deception that you noticed. :-D :-D
Offline GH
« Reply #942 on: March 12, 2010, 10:28:10 AM »
Troy, you still get a lot of slop in the delivery of the spark, plus using one coil instead of 8. You would like the coil packs.
Offline bvillercr
« Reply #943 on: March 12, 2010, 12:05:52 PM »
Your right coil packs would be great, we used to run the electromotive ones when we ran dual plugs.  We have other goodies on our wish list before we worry about the ignition system. :cheers:
Offline bvillercr
« Reply #944 on: March 12, 2010, 06:21:47 PM »
First on our wish list is a Racepak system and then the water injection, then we will see after that. :cheers:
