Author Topic: Getting ready for Bonneville(rebuild)  (Read 1911867 times)
Offline revolutionary
« Reply #2340 on: May 18, 2018, 08:45:47 AM »
It's been too quiet over here. What's going on? You guys racing this year?
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
« Reply #2341 on: May 18, 2018, 02:51:43 PM »
   We held off on El Mirage as Linda has been having radiation treatments since December and I need to be with her.
   Not making Bville either but hopefully Nov. El Mirage.
« Reply #2342 on: May 18, 2018, 06:23:56 PM »
John and Troy,
Sorry to hear about Linda. Thoughts and prayers for her.
« Reply #2343 on: May 23, 2018, 10:58:23 PM »
Sorry to hear that. Best wishes and thoughts going out to yall
Breaking Wind #9614
Offline bvillercr
« Reply #2344 on: June 13, 2018, 07:20:53 PM »
Looks like my photos are back up:)
Offline bvillercr
« Reply #2345 on: June 13, 2018, 09:59:26 PM »
Desoto and Rev, thanks for the well wishes it’s a tough time right now.
Offline bvillercr
« Reply #2346 on: June 29, 2018, 01:26:26 AM »
Some future plans discussed tonight: before we race again we need to pull the engine and replace all of the sleeves and pistons, pull the water tanks out and modify the tin underneath to creat more space for the panhard bar, replace rear brake system.  Hopefully we will race again next May!
« Reply #2347 on: July 02, 2018, 05:42:35 PM »
  Maybe Nov? We got away from our original chassis tune because the sheet metal on the chassis was bottoming out on the panhard bar. there's adjustments on the shock mounts so we moved the shocks up + the spring platforms. this changed the set up to much + made the car to stiff. So by cutting the sheet metal to make space for the panhard bar we can get back to the original setup.
« Last Edit: July 02, 2018, 06:00:38 PM by jl222 »
« Reply #2348 on: August 21, 2018, 08:08:54 PM »
Every few pages I like to put up videos of our runs so if people want to find them they can locate them a little easier.  These are some of our better videos.
     These are in 2008
http://www.youtube.com/watch?v=mHUEA-pScY8
http://www.youtube.com/watch?v=Udo7XM472Qk
                 2009
http://www.youtube.com/watch?v=55XA0vrNNj0
                 2010
http://www.youtube.com/watch?v=yxkEtJ1b6AI
http://www.youtube.com/watch?v=kLG0JFzazrs
 More from the past
  Rob...here's the videos. The 1st one is El Mirage, car hooks up and goes 152 mph in 10.2 sec. Then track turns bad which you can see from other video.
  Another year already :-o
  The second video shows the in car view of the 1st video, you can see the throttle on left of hood and how busy Troy's
hands are steering back and forth, saving a spin.
  Makes me think that faster steering would help.
  Hurry up EL NINO and flood the lakebed, so the 222 Camaro could make a full pass 8-)
 I like to watch these videos, gets me inthused :-D
« Reply #2349 on: August 21, 2018, 08:50:31 PM »
The last two videos are the last until Monday where we will take some more.
http://www.youtube.com/watch?v=Bcx2F6v4jog
http://www.youtube.com/watch?v=DFcpyvs5na4
 Dyno results, more about dyno pulls around pgs 80-85 there abouts :-D
Offline lvsalt
    • http://www.dcwaterjet.com
« Reply #2350 on: August 21, 2018, 09:10:46 PM »
 :cheers: :cheers: :cheers: :cheers:
Gary Cole     DCWATERJET Z
« Reply #2351 on: October 13, 2018, 09:08:56 PM »
  Troy came out today and we worked on installing new  hat, rotor and caliper on left rear. Of course it didn't just bolt right up.
  Housing ends must not have been welded  in the exact spot and a bit angled. So not parallel with rotor. caliper would not install without grinding down mounting pads on caliper. Almost got it just a few more thou of shaving. Plenty of metal left.
  Hope other side goes better.
Offline bvillercr
« Reply #2352 on: October 20, 2018, 07:53:03 PM »
A few years back we noticed the panhard bar hitting the tin above it on the car, so we changed the shock position to help with clearance.  Ever since the car seemed to not handle as well.
The last photo with the panhard sticking through is an over exaggeration of how far it will come up, but you get the idea.
« Reply #2353 on: October 20, 2018, 11:14:48 PM »
  The intercooler water tank sits above the cut out tin, so we need to cut out the bottom of tank to match. Thinking about using Flex Seal.
   Clean up tin and repaint.
  Also found out why rotors were rubbing on disk brakes. Ford 9'' Axle slipping on bearing :-o
« Last Edit: October 20, 2018, 11:18:27 PM by jl222 »
« Reply #2354 on: October 20, 2018, 11:29:02 PM »
I always tig tack the retaining ring. It's an old oval track trick.
