Author Topic: Getting ready for Bonneville(rebuild)  (Read 1897897 times)
Offline Lowwlife
« Reply #2175 on: February 08, 2016, 07:47:36 PM »
Few pics from Mojave.
« Reply #2176 on: February 08, 2016, 10:07:49 PM »
Cool pics. Thanks. :cheers: :cheers: :cheers:
Offline bvillercr
« Reply #2177 on: February 09, 2016, 12:36:46 AM »
Wow, very nice photos!  Thanks for sharing :-D
« Reply #2178 on: March 15, 2016, 04:08:26 PM »
 New EFI injector harness's have arrived [we decided to replace the y harness and both the other harness's even though one was alright, just to be sure] Just need to replace injector 0 rings and every thing else should be ready.
 A lot going on with new house. Trying to get a pool built and El Nino not helping.
  Should run El Mirage May meet [El Nino?] and spoiler mods should help traction.
Offline bvillercr
« Reply #2179 on: April 11, 2016, 10:46:14 AM »
It's that time of year to get things done, we will be working on the car this weekend and if all goes well we will fire her up😎
« Reply #2180 on: April 11, 2016, 12:44:04 PM »
We'll be listening for the video!!!  :-D :-D :-D
Offline Captthundarr
  • In line
« Reply #2181 on: April 11, 2016, 05:53:41 PM »
I swear I can hear it from here......
Offline bvillercr
« Reply #2182 on: April 16, 2016, 10:44:04 PM »
We installed our new injector wiring, the faulty "Y" was also replaced and we were having some o-rings that were leaking today so that took up most of our day.  I had forgotten how little room there is to install those wires under the plenum of the manifold!  Any way we are 90% ready to fire the car in which we will do tomorrow around 1.  Here's a shot of our injector wiring.
« Reply #2183 on: April 18, 2016, 03:33:46 PM »
 We got it fired up after some [a lot] of frustration. We tested the new harnesses to see if injectors were squirting fuel before install in manifold.Right side worked left didn't switched sides at why connection, same thing. plugged connectors in and out several times no difference.
Next step. main connection where y connector plugs in. Plugged in and out several times problem fixed all injectors squirtimg :cheers:
 Installed injectors in manifold, injector leaking gas when testing for leaks, new O-ring finally ready to fire after more leaks and loosening mounting of fuel rails.
 Fired her up, #1 not firing? Same problem as before, check spark, remove plug and gap is closed. Plug had come loose from wrench
when checking for fuel in cylinder and must have closed up when trying to get wrench back on :roll: Easy fix.
 Fired her back up, runs good then no firing on left side, unplugged main harness at y, sprayed with brake clean, blew it out. problem fixed.
  Fired up and runs good, blew cob webs loose from ceiling over 20 ft up, shifted trans through gears, every thing good. Ready for El Mirage :-D
 Troy has videos but had to leave for company meeting in Pittsburg and won't be back for a week. Maybe he can post from his phone?
  JL222 :cheers:
« Last Edit: April 18, 2016, 03:38:56 PM by jl222 »
Offline revolutionary
« Reply #2184 on: April 18, 2016, 06:04:29 PM »
rinse and repeat  :-D
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
Offline Speed Limit 1000
« Reply #2185 on: April 19, 2016, 02:01:55 AM »
  JL222 :cheers:
Kansas?
Offline bvillercr
« Reply #2186 on: April 20, 2016, 11:05:59 PM »
The home of the Steelers, I'll try to post videos tomorrow:)
« Reply #2187 on: April 20, 2016, 11:50:18 PM »
« Reply #2188 on: April 21, 2016, 01:19:33 AM »
Pittsburgh. Go Steelers. Stairway to seven :cheers:
« Last Edit: April 21, 2016, 01:21:04 AM by Speed Limit 1000 »
Offline bvillercr
« Reply #2189 on: April 21, 2016, 08:01:01 PM »
First start was ok, but cylinder 2 isn't firing.
Second video the engine starts to run a little rough so I shit it down.
The odd side of the engine wasn't getting any electrical signal and not firing.
This last video we run through the gear and build some heat and ran much better.
« Last Edit: April 21, 2016, 08:05:54 PM by bvillercr »
