May 23, 2013, 11:26:10 AM *
Pages: 1 ... 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 ... 129   Go Down
Author Topic: Getting ready for Bonneville(rebuild)  (Read 257482 times)
Frankie7799, gkabbt and 1 Guest are viewing this topic.
bvillercr
« Reply #1440 on: June 11, 2011, 09:52:17 AM »
Video update time.  Every once in a while I will post our old videos so they are found fairly easy.  Not sure how many pages between each posting on this build diary but seemes like it has been a while. afro
El Mirage Nov. 08 sunday
http://youtu.be/NJZbf4_IUeo
same run but inside view.
http://youtu.be/L8BabM070vc
El Mirage Nov. 08 saturday.  I was a bit more aggressive on this first run. undecided
http://youtu.be/mHUEA-pScY8
same run inside view
http://youtu.be/Udo7XM472Qk
bvillercr
« Reply #1441 on: June 11, 2011, 10:11:09 AM »
Dyno session in the late night/morning hours.
http://youtu.be/iJApvHuDpL0
We did some tuning during the day time too.
http://youtu.be/8ksf9rHChFM
results for previous pull.
http://youtu.be/DFcpyvs5na4
Bonneville speed week 09.  This is what happens when you don't clutch it when the wheels get loose in the lower gears. grin BTW: this is not me. grin
http://youtu.be/N_CEUEoBgq8
Bonneville speed week 10.  First GoPro video, much better quality.  Shake down pass 270mph
http://youtu.be/kLG0JFzazrs
Tom Slick
« Reply #1442 on: June 13, 2011, 08:13:44 PM »
Hey Troy,
Are you guys planning to run at El Mirage this year, or are you running Bonneville only?
bvillercr
« Reply #1443 on: June 13, 2011, 11:11:30 PM »
If we/car can survive Bonneville this year we will run El Mirage in November.  We have too much to do To the car before Bonneville to make any meets prior. cheers
bvillercr
« Reply #1444 on: June 19, 2011, 11:01:53 PM »
Front window is mounted and just needs each screw to be counter sunk so it is flush to the window.
Getting the spoiler ready for a window.
Drilling the holes that attach the spoiler to the window.
Finally have the deck lid window mounted.  Just have to place a few fasteners through the window in a couple strategic areas to make sure the window stays attached to the car.
Bville701
« Reply #1445 on: June 20, 2011, 12:09:39 AM »
WOW!!! That looks REALLY good!!! GREAT job!!!   cheers
Ryan LeFevers
701 C/GMR
bvillercr
« Reply #1446 on: June 20, 2011, 10:06:37 AM »
We will check today and see if we can pick up our parts.  The block has been bored, just waiting on the crank and heads to be finished.  cheers
Livin1072
« Reply #1447 on: June 20, 2011, 11:48:56 AM »
Wow I'm caught up on all 97 pages  grin
Congrats on your documented process of overcoming obstacles that offten detour the most ambitious goal chasers!!
After running numerous payment events I'm excited about running on the salt this year!!  Thank you for the motivation displayed through your dedication to achieve.   cheers
Team SGR Mr Turbo Racing
259.9 mph Texas '09 / 264.3 mph Maxton '10 / 265.1 mph Loring '09
jl222
« Reply #1448 on: June 20, 2011, 02:01:20 PM »
  Thanks Livin...I guess being stuborn helps grin We always thought we were on the right track using centrifugal superchargers but we have had our problems using two. When Procharger came out with the
4000 cfm F3-R39 it solved that problem as we now can just run one.
  Hopefully with our new top fuel type pistons and some fine tuning it will hold together and make a couple of 300 mph + recorded times.
  Stop by at speedweek.
                         JL222 cheers
If in doubt, it probably IS a mistake.
« Reply #1449 on: June 21, 2011, 08:11:46 PM »
Killer job on the rear window - heck, the whole darned car.  cheers cheers cheers
"Information - we want - information"
bvillercr
« Reply #1450 on: June 22, 2011, 06:56:59 PM »
Had a little set back today.  The heads we have been running since 92 are no longer good.  The heat we created last year got the beat of them! evil  we are seating for new ones that have the stock dimensions valve length and manifold bolt pattern amongst many other variables.  Hopefully we can get heads without having to replace the manifold. grin
bvillercr
« Reply #1451 on: June 26, 2011, 12:58:17 AM »
We got a few things done today.  Since the front window isn't 100% finished, I took the window out and prepped the dash for a fresh coat of paint.  Today we did get our passenger side lexan installed.  Here is a look at how we traced and cut the lexan.
The finished piece with the window track installed.
Window installed minus the brackets we will use to hold the window in place.
jl222
« Reply #1452 on: June 26, 2011, 11:59:53 AM »
   Bvillercr.....Those fotos sure look easier than it was grin
bvillercr
« Reply #1453 on: June 27, 2011, 10:16:14 AM »
Glass window traced onto the lexan, and how we cut it.
The inside dash is painted winter grey and the area where the window will sit is a gloss black.  Once we counter sink the screw holes the window will be on for good.
Driver side window is now installed, much easier than the passenger side.  Now we need to order our clamp down latches and install those and the side windows will be complete.
jl222
« Reply #1454 on: June 27, 2011, 11:07:15 AM »
  We are hoping to use the latches you see on the pro-stock side windows, as we need to roll the windows
down to steer the car in and out of the trailer. We also have to turn on the air to the trans or it will not roll
backward.
  Anyone trying to use non-formed Lexan on curved glass is in for a lot of cussin tongue  Ours is pre-formed.
  Were also looking to use Duze-fastners on the side of the rear window as I'm worried that air could pull
the glass away from the body and rip off the whole deck lid spoiler and all, with disastrous results. The Lexan 3/16'' is flexable as the stock glass is very sturdy.
Pages: 1 ... 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 ... 129   Go Up
Google visited last this page May 13, 2013, 10:20:23 PM
