At one time I was real negative on the 9 inch efficiency but from testing that I have heard about and also thinking about it a little in the ratios that you would want at B'ville the 9 inch is a good choice. Unless you happen to have a couple of thousand HPs and a ton of weight to make it hook up you will never brake a 9 inch. When you get into the higher ratios, like 3 to 1 or less, the pinion starts to get lots of teeth and the sliding action between the pinion teeth and the ring gear greatly decreases and the efficiency goes up.
Another area is the gear oil itself. Run the lightest you can get away with and also the smallest amount. The real trick would be to dry sump the diff and spray the oil on to the ring gear just past the point of mesh. I talked to a couple of FWD guys once and they had a Chevrolet 4 cylinder with a BIG turbo, claimed it made 1800 hps! anyway they ran a 9 inch diff in the front and since the motor was infront of the front axle they ran a custom built gear box that changed the drive direction to get the power into the 9 inch. Well the custom box was pretty beefy and they normally ran 2 qts of 140 wt in it, they checked the temp one time after a run and it was over 250 deg F! so they next run they put in one qt of ATF,
No heat and they ran 8 or 9 mph faster and a couple of tenths quicker. So there is power in the diff.
