The highest/ cleanest air pressure on your car will be at the base of the windshield.
That is why some take air for the motor there rather than a big, forward facing scoop.
The speed you will expect to be going will cause air flow in excess of anything the fans can stir up.
A recirculating setup (closed loop) will only cause the dirt you didn't eat the first time to come back.
You have the best system built in.
As for the foam, check on the cure time and you may find that after inspection Friday, you can apply it and it will be cured by the time you run it Saturday.
Put your trim covers on right after you spray it and it will find any unsealed cracks.
