Well I have managed to shed off what was almost a burn out on my part from putting to much time into the bike. I have paced myself and feel like I get more done by just stopping when need be and come back at it fresh another time.
I had to cut off the axle block adjuster and step it out to match the width off the brake bracket.
Here is the offset ready to welded in place.
Finished
Got all of the final wheel spacers cut and installed as well as the axle adjustment spacers.
Drilled a hole in the gusset for the steering stops
Here is the solid rod that will be used for the stops.
Getting rid of the sharp edges.
In place and ready for welding.
Finished
Now onto the tank mounts, here is what is on the tank.
Here are the brackets that will hold the rubber grommets in place.
Starting on the rear mount.
Finished rear mount.
Side view of tank mounted in it's final resting place.
I will get back to work tomorrow and hopefully start on the tail section which may be modeled after a sportbike tail............I will just have to wait and see until I get out there as I have ideas I am just not sure if and how they will work.
Scott
