Author Topic: My LS bike build  (Read 86140 times)
Offline joea
Re: My LS bike build
« Reply #45 on: July 08, 2007, 10:42:08 PM »
Freakin awesome...!!!!!
TOTALLY amazed at what folks can get accomplished
with a bunch of passion.........
when slim talked of ya not makin it, i was thinking....yeah
I dont see how your gonna get that much work done in such
a short time.....keep it up...
Joe :)
Offline isiahstites
« Reply #46 on: July 08, 2007, 10:46:37 PM »
Joe :)
I am working my ass off after work and pretty much spend my weekends working on it..........ELMO is this week and it is going to take a day of work away from me, but I need to go out and support my friends.
Scott
« Reply #47 on: July 09, 2007, 11:59:25 AM »
Got my new grips put on and the clip-ons in what I believe are there permanent location."
Don't forget to leave clearance for the gloved hands that'll be holding on to the clip-ons.  We check to make sure that your fingers don't get pinched 'tween clip-on and bodywork/frame at full lock in both directions.
Check during assembly -- it'll save time and stress versus getting into tech, having an inspector point it out, then you have to adjust and get back in line.
Offline isiahstites
« Reply #48 on: July 09, 2007, 07:31:47 PM »
Thanks Slim, I will check it when I build the steering stops.
Scott
Offline bvillercr
« Reply #49 on: July 09, 2007, 07:37:10 PM »
Just got a buckle down and get er done.  Looking good, keep it up.
Offline isiahstites
« Reply #50 on: July 10, 2007, 11:53:11 PM »
The cases will be back from NRHS tomorrow afternoon with the bottom end assembled and fresh off of the balancing table. I hope to start final motor assembly very soon.
Finished up the coil mounts this evening and took the bike off of the lift so I could check steering clearances for the steering dampener and stops. I will start on both of the items tomorrow.
The bike off of the lift measures 36 inches to the top of the triple tree.
Offline ol38y
« Reply #51 on: July 11, 2007, 01:07:20 AM »
Hey Scott. looks awsome. I think you need to put a fairing on it. That'll put you in a different class but I'll suffer thru it, hahaha. I talked to Dan the other day and he said to not for get to change the oil!!! He also said that was the first time he had ever been able to finish an 18 pack before he got a motor balanced, but you should still be all right....  :-o  Lookin good tho and hope to see ya there.
        larry :evil:
Larry Cason
2010 BUB 1350 M-PG record
Offline isiahstites
« Reply #52 on: July 11, 2007, 08:39:26 AM »
I talked to Dan the other day and he said to not for get to change the oil!!! He also said that was the first time he had ever been able to finish an 18 pack before he got a motor balanced, but you should still be all right....  :-o          larry :evil:
Funny! To bad I know they outsource the balancing........are you going to to EM this weekend?? Did you figure out what carb you are going to use??
Scott
Offline ol38y
« Reply #53 on: July 11, 2007, 10:13:11 AM »
Hey Scott. Gonna try and make EM, it's gonna be close. I've got the 42 mounted up right now but I have a 45 on the way. But right now I gotta go measure my triple clamps.....
Larry Cason
Offline isiahstites
« Reply #54 on: July 11, 2007, 04:08:48 PM »
If you don't get the bike ready are you going to come out as a spectator??
Offline isiahstites
« Reply #55 on: July 11, 2007, 09:12:32 PM »
My motor came in today from being balanced with the bottom end put together.
Here is the steering dampener I bought it is off of an 06' Suzuki GSXR and some angle iron to make the bracket to hold it to the frame.
Here are a few shots of the finished bracket.
Here is the bracket welded to the down tube.
And a few shots of the dampener mounted to the bike.
Offline 1212FBGS
    • http://www.motobody.com
« Reply #56 on: July 11, 2007, 09:29:23 PM »
stop righting... start working.... you need to load by sat morning.... hey where did ya get those cool clip ons?
kent
Offline isiahstites
« Reply #57 on: July 11, 2007, 09:39:46 PM »
That's not going to happen Kent! I got the clip-ons from some guy in Vista.
Scott
Offline RayKimbro
  • Go fast, be safe - don't mess up
« Reply #58 on: July 12, 2007, 08:55:36 AM »
There's LOTS of stuff to like about this bike - not the least of which is the enthusiasm w/which you're pursuing it.  Thanks a BUNCH for sharing the build w/all of us - and I wish you much luck, learning and fun out on the salt.
Remember that fast is more than a number - and rinse that thing w/SaltX when you get home!
Don't BS on the track - that's what the internet is for.
Offline isiahstites
« Reply #59 on: July 12, 2007, 09:04:50 PM »
Thanks Ray, however I had a hard time reading your post with that rat-dog-demon-cat thing starring at me..........
Thanks for the tip on the Saltx, my bike will get tore down when I get home to actually paint it with something other than the rattle can paint I plan on using give it some color and keep it from rusting.
Scott
