Been a busy weekend! I got my spare motor put in so I could line up the rear sprocket and figure out the offset needed for my trans sprocket. All of my sprockets are on order and being made at PBI. Had my heads flowed and was pleasantly surprised to find out that the motor has the potential to make about 133 hp if I can tune it and build a good exhaust system. Got lots of parts ordered and on the way. I have about 30 days left and it is going to be close. I hope I can make it............
Got the footpegs and shifter completed.
Grinded, shaped, drilled and sandblasted peg mounts.
Mounts welded on.
Shifter rod was made of aluminum stock. I drilled and tapped the ends for the heim joints.
Motor mount is almost complete to include a mounting location for the two Dyna coils. The coil portion still has alot of work as I need to trim the piece down once the thread bungs are welded to the plate.
Another view of the motor/coil mount.
Got my new grips put on and the clip-ons in what I believe are there permanent location.
