May 20, 2013, 03:51:13 AM *
Pages: [1]   Go Down
Author Topic: Choice of front ends for a STR  (Read 1186 times)
panhead_pete
« on: April 13, 2007, 10:40:47 AM »
Am looking at commencing building a STR class car, initially with a relatively small motor and perhaps stepping it up each year once I gain more experience. Now Im a fan of doing things once and doing it right. I really would apprecaite some input in relation to the choice of front end. Is a dropped I beam the best route or should I consider an aftermarket independent set up. My ultimate gaol is 200 +, perhaps as an A or AA engine. The other thing to consider is it will need to maintain a roadworthy status when not on the salt. Thanks.
This year I learnt how to race on the 1/4, next year it will be the salt.
Blanding, Ut..a small dot in the middle of nowhere
« Reply #1 on: April 13, 2007, 11:15:23 AM »
Am looking at commencing building a STR class car, initially with a relatively small motor and perhaps stepping it up each year once I gain more experience. Now I'm a fan of doing things once and doing it right. I really would appreciate some input in relation to the choice of front end. Is a dropped I beam the best route or should I consider an aftermarket independent set up. My ultimate gaol is 200 +, perhaps as an A or AA engine. The other thing to consider is it will need to maintain a roadworthy status when not on the salt. Thanks.
There is nothing wrong with a dropped axle except that most of the components, axle, drag links, spring and wishbones or 4-link are all on different planes, so you have a lot of components that are out in the wind and increasing frontal area.
One of the earliest approaches that I've seen to over come that is the famous Beatty lakester.  The picture above shows what he did to overcome the bad aero you can get with a dropped axle.  He took an "A" axle that has the least amount of drop in it and turned it upside down and re-bent the ends to get the camber and scrub radius correct again.  That also further straighten the axle so it is almost like a straight axle.  Then he reversed the spindles and bent them so the drag link across the front is right in front of the axle.  Then by working with the spring perches he aligned the spring pretty much behind the axle.  Finally using split wishbones they are also behind the axle and have less vertical height than say hairpins or 4-links.  I don't see why you couldn't even run this on the street, but if it was me I would do this for the salt and have a second dropped axle for the street.  I was going to do this for my lakester and picked up a couple "A" axles, but then decided I wanted to do something yet different for the lakester.  The A axles can be had pretty cheap as everyone wants a dropped axle.
Here is a newer approach and is on the beautiful Kelly & Hall lakester.  It uses a straight tube axle with the other components out of the wind as much as possible.
good luck,
jimmy six
« Reply #2 on: April 13, 2007, 11:33:30 AM »
If you are planning to use the vehicle on the street, don't do what the pictures show. The intent is good, but the ackerman is backwards and will cause many problems on the street when turning. Many use what you see in many different classes but only for racing. I did for years but finally turned it around and like it much better. Also the caster for a 200 mph car is a lot different than the street; makes for some "popeye" arms. Good Luck
« Reply #3 on: April 13, 2007, 01:43:17 PM »
Good points JD.  Just shows that it is hard to setup a car to be "competitive" on the salt and still keep it streetable.
c ya,
Pages: [1]   Go Up
Google visited last this page May 18, 2013, 12:51:35 PM
