Insight, plans where to start, mistakes to avoid, links, pics, help, starightjacket for even attempting to do this.......We are very interested in getting to the salt, any help would be great. Are platform as it stands now is to run a VW engine, starting with 1600 cases, we are wanting to do it grass roots style, starting out just to get are feet salty , then move up as we get experience....Any Insight is a great help...
If I was going to do it,I would not start with a Type 1 case.
I'd use a Type 4,and weld up some new AMC castings.
Or convert a Type 5 to aircooled(aka Oxyboxer conversion) ,
and use after market Type 1 heads,like Competition Eliminators or Autocraft.
Even then,stock 4 valve heads are frequently better than
aftermarket 2 valve heads,so you are fighting a steep uphill battle.
G is 2015cc IIRC.
Larry Widmer get 297 hp from NA 2 liter Honda motors.
If you really like the pancake 4 cyl,you could adapt Subaru heads
onto a Type 1 or Type 5,because the bore spacing is the same.
Makes more sense to run the whole Subaru motor,the bottom end
will be more reliable with a 5 bearing crank,compared to only 3 on the VWs.
