The frame structure should contain you equally all around.
The inner skin is required to keep you from poking out between the bars.
For the floorboard, consider the motion required for you to get in and out and you might find that a skid resistant surface like thin diamond plate would work best.
Material choice of aluminum, steel, and thickness is less important than secure fastening methods.
