Nolan White had an all wheel drive with an input shaft that was based in a sprint car rear end and narrower than the BBC, wheels and all.
I thought all wheel drive is no longer allowed(?) So this may make FWD a good option for small streamliners.
I was kind of thinking about the bike engined streamliners, the chain drive would be relatively easy to work into some seriously shortened half shafts.
Suspension helps with steering and traction (and keeping the fillings in your teeth) so if the front is doing both, could you dispense with the rear suspension and narrow up the backend even more? The rough sketches in my head are starting to resemble an airfoil...
