Aero downforce is good for a lot of things in LSR, but get it sideways and flying won't be any trouble it will be the landing.
As somebody who has glider time, I can say landings are easy - you will land! Some landings are bumpier than others however.
Good old P-51 airfoil looks pretty deep, as well as the GAW.
Please note the figure 2 shows the % as the point the flow becomes non-laminar, not the point of maximum chord.
http://www.dreesecode.com/primer/airfoil5.htmThis from the link alludes to why I think we're as well off with non-laminar airfoils. This doesn't even factor in cutting holes for wheels and break lines for canopies.
"Consider the builder?s ability to control the wing contour during construction and flight. The surfaces of metal airplanes tend to ?oilcan? during flight and this can change the contour enough to trip the boundary layer.
When using composites, it?s important to keep close tolerances on the airfoil contour. Contour control of a surface isn?t just a step-height allowance; it depends on the chord length that it occurs over. Aluminum? Forget about it."
