Im after pics and recources /plans etc of the small engine sized (G H I ) streamliners , what was successful ,what was not ,starting planning stage for a streamliner and as I only have the resources for one shot only Im keen to do it correctly
Cheers
Gary
The Costella Streamliner #988 and the McBride & Moreau Streamliner #286 start both very successful in 1996 with a very similar, very small streamliner. From 1996 to 2001 the record was pushed from both teams from 178 mph to
248 mph (I/GS and I/FS) under SCTA/BNI - Jim True run FIA with the Costella to 253 mph, which is only 5 mph under the current Blown FIA record.
Meanwhile, Rick Yacoucci is using the Costella streamliner very successful with bigger engines up to 360 mph with 92 ci blown engine and 316 mph in I/BFS.
Both cars shows possible solutions for a very fast concept. The different between the Costella and the McBride & Moreau concept is, that the Costella concept works only without suspension and a flat, very close to the ground positioned, floor.
