I need a cell for my bike to run in A class at speed week. I wasnt able to find anything about what kind of material was required other than "craftsman style workmanship" or whatever it was. I can have one made. a 6x6x7" should net a tick over a gallon. simple screw on/off cap on top, 2 3/8" NPT weld in fittings on bottom with 2 90* AN fittings, one 6, other 8. those will have two Jiffy Tite quick disconnects to make switching between tanks easy. it will also have a rubber mount but rigid bracket to mount in the stock location. it will have a long bracket that extends over the plenum and mounts to the OEM front frame mount.
I found this on Jeg's and the only limitation I see is not knowing what the lower size outlet is or if it can be modified. return on top looks fine. would this material be acceptable for a bike in A. it will not have any additional shell. anyone else have any other ideas? thanks.
JAZ NHRA-accepted cells include 1/4'' nipple lever handle petcock outlet fitting with 1/4''nipple vent fitting in the top. 1-quart features molded-in 1/4''-20 mounting inserts. 1&2 quart features twist lock cap with check.
