At least 2 of the failed attempts used a double cable system with 1 in tension on each side of the front wheel.
They used the best materials available and the preload all but eliminated the stretch/flex.
It was a failed attempt to eliminate bump steer.
The result was the friction prevented the caster in the setup from settling to a happy center and the operator was always attempting to catch up.
It was a lot like getting yourself out of a tank slapper, sometimes you would do well to take both hands and slap your face while the bike settles down.
Too much damper can do the same thing as Vesco taught Campos on the 2nd BOB George liner.
"Not everything you think you see is what you think it is."
