I've heard you mention several times about using an OD ratio as the third gear in Hooley's trans. Is that because the top gear must always be 1:1, or is there some other reason? You will use the OD as the final drive gear, right?
Yep just like J.D. said except ours are:
1st = 1.923, 2nd = 1.331, 3rd = 1.000 (the original 4th) and 4th = 0.931 (where the 3rd gear set normally resides). Like he said they can setup the shifter so you have a normal H pattern. You can also go with a ratchet type shifter, but we wanted to be able to go from any gear directly to neutral if needed.
JD with the G-force the highest 1st I could find was the 1.923 I'm surprised you could find the 1.6.
Before with the muncie's 2.2 1st we pushed the car to about 45 before it pulled away. Now we will probably push 5 mph faster or so, but will adjust that as we go. My truck can get the car up to 45-50 in a pretty short distance, so that works.
The motor wouldn't really pull but a little past 7000 last year even thought the HP peak is about 7400 with our present cam. That was with 8 lbs. boost. We hope with 14 lbs or so to pull the 7400, but the way it is geared now with the new transmission 7000 is 257 mph in 4th and 7500 is 256 mph in 3rd. Our goal is a little over 250 this year, so depending on how the motor pulls at the higher boost we have too options to get there, less rpm in 4th or more rpm in 3rd. We will only loose about 300-400 rpm on the 3-4 shift.
Like JD said there is about every gear ratio you could ever want in each gear to select from except for the one gear that has to be 1 to 1. Their 5 speed works the same way with one gear 1 to 1 and most of the rest can be overdrives or underdrives. I wanted a 5 speed at first, but after guidance from Tom can see it wouldn't do much for us. A high 200-300 mph car could make better use of it.
c ya,
