The lesson to all of the race organizations is that it is much easier to supply the fuel and control the situation then try and bring a chemistry lab to analyze all the combinations.
Harold, I ran oil of wintergreen.
I'm not giving on the performance gains, but if nothing else it smells great, and I don't mean the oil of wintergreen smell.
If detonation is your only problem:
| | Btu/lb | AF | Resch | Motor |
| | 1 atm | Ratio | | |
CH4 | Methane | 23,650 | 17.2 | 120 | 120 |
C7H8 | Toluene (methyl benzene) | 18,245 | 13.5 | 120 | 109 |
C8H10 | Xylene-m (1,3-dimethyl benzene) | 18,434
| 13.7 | 118 | 115 |
C2H6 | Ethane | 22,169
| 16.1 | 115 | 99 |
C10H22 | Isodecane (2,2,4-tetramethyl hexane) | 20,460
| 15.1 | 113 | 92 |
C3H8 | Propane | 21,484
| 15.7 | 112 | 97 |
C7H16 | Triptane | 20,614
| 15.2 | 112 | 101 |
C8H10 | Ethyl Benzene | 18,487
| 13.7 | 111 | 98 |
C6H12 | 1,1,2-trimethyl cyclopropane | | 14.8 | 111 | 88 |
C2H60 | Ethanol | 12,780
| 9 | 107 | 89 |
CH40 | Methanol | 9,770
| 6.4 | 106 | 92 |
Good luck putting Methane in the tank. Bring a cow.
But detonation isn't your only problem. If you are looking for a land speed record you are looking for the biggest bang. Notice that Triptane gets you 20,614 btu's, Methane 23,650, Methanol 9,770. Nitromethane isn't on the list because it doesn't have an octane rating due to it's combustion properties. It gets you 5,160 btu's
The trick here isn't btu's per pound of fuel, it's btu's per pound of air, and that's where the air/fuel ratio makes the real horsepower. Internal combustion engines are air limited.
| | Btu/lb | AF | Resch | Motor | |
| | 1 atm | Ratio | | | btu/lb air |
CH3NO2 | Nitromethane | 5,160 | 1.7 | | | 3035 |
C2H5NO2 | Nitroethane | 7,790 | 4.1 | | | 1900 |
CH40 | Methanol | 9,770 | 6.4 | 106 | 92 | 1527 |
C2H60 | Ethanol | 12,780 | 9 | 107 | 89 | 1420 |
C3H6 | Propene (propylene) | 20,943 | 14.8 | 102 | 85 | 1415 |
C6H10 | 1,5-hexadiene | 20,170 | 14.3 | 71 | 38 | 1410 |
C5H8 | Isoprene (2-methyl-1,3-butadiene) | 19,998 | 14.2 | 99 | 81 | 1408 |
C4H8 | Butene-1 | 20,727 | 14.8 | 99 | 80 | 1400 |
C4H10O | Butanol | 15,500 | 11.1 | | | 1396 |
C5H10 | Pentene-1 | 20,590 | 14.8 | 91 | 77 | 1391 |
C5H8 | Cyclopentene | 19,672 | 14.2 | 93 | 70 | 1385 |
C6H12 | Hexene-1 | 20,495 | 14.8 | 76 | 63 | 1385 |
C3H8O | Propanol | 14,500 | 10.5 | | | 1381 |
Gasoline averages about 1359 btu's per pound of air. Triptane 1356. As well as knowing the detonation gains, the heat gain is where you want to go.
Methanol gets you about 22% more bang and runs cooler. Never could understand setting a fuel record with gas.
I do understand running Methanol. Nitromethane gets you 123% more bang, but you can see why the molten trophy deparment gets big in a hurry.
Properties of hydrocarbons:
http://www.me.mtu.edu/~slpost/CLASS/hcprop.html
