This might not fit in here and maybe I misunderstood it at the time, but '91 was my first year on the salt and they were running both directions if you qualified for a record.
It was my understanding that the record had to be set in the same "physical mile", so if you qualified for a record going down in the 5th mile then you would have to average your time in the 3rd mile coming back as that was the same physical mile.
Was that correct??
If so then later when the course layout, due to decreasing salt, dictated no return runs for safety purposes (dike in the way) it was left that the record had to still be over the same physical ground, but now that could be the 5th mile on both runs. If this is the case like today then you had an advantage since you aren't averaging a shorter run against a longer run, if this makes sense. I think in this period a lot of records fell and re-established themselves with the new procedure.
I'm not complaining about this as changes have to be made to deal with the salt and conditions that are given to us, but I could see where some of the old guys might have felt their records were maybe taken away by a procedure change and not necessarily better equipment. You could say the same going back further to the time when it took 3 runs and not 2 to set a record. So I don't feel SCTA really has any explaining to do for this quote from Dan's post
Will it happen again? It won't if people play fair and follow the rules, but it did happen.
I have a question though. A few years ago when Nolan set the record at Speed Week and they were running the return record runs to the south, were they averaging the same mile of the run, or the same physical mile??
Sorry if this shouldn't be on this thread and yes Dan at BUB you get a five mile run up (if you want to use it all), and then are timed in the 6th mile, so it isn't apples to apples comparing the BUB course and the SCTA course. Burklands, Nish, and Main ran on the BUB course and had helped to set it up earlier if I remember right.
c ya,
