I think those sizes may be quite a bit larger than stock tires for the CB350. If I have the stock rim widths right (1.6" front a.k.a WM0, 1.85" rear a.k.a. WM1) they were set up at the factory with narrower tires like 3.00-18 or 80/90-18 front and 3.50-18 or 90/90-18 rear. Even those tire sizes seem a bit wide for the rim sizes - back in the 70s Honda seemed to fit wider tires on a rim than the tire manufacturers recommend these days. On a smaller displacement bike on the salt you might get a small advantage in rolling resistance with a skinnier tire. I think you could even go down to a 2.75-18 front and a 3.00-18 rear on the stock rims. If you're flush, Avon has race tires in the proper sizes. Don't know how much advantage they would have beyond a higher speed rating than some street tires in those sizes. Avon Streetrunners are S rated - 112mph and reasonably priced. I run S rated Heidenaus on my nitrous CB77. Record in the fastest class I run in is 108, so they are good for now. I run a very skinny front, 2.50-18 K40, on a kind of oddball 1.4" skinny wheel. Rear is a 3.00-18 K33 on an XL350 aluminum rim that is, IIRC, 2.15" a.k.a. WM2.
