I have heard similar accounts, but why? Is it because with a posi, if one side loses traction, the other side will keep pushing to the side with no traction, causing a spin? If so, then what are the drawbacks with an open rear?
I have heard to use a spool, but if an axle breaks, or one side loses traction, is it the same result as a posi?
Is the open rear safer because if a tire breaks loose, you just go up in smoke until you back off the throttle, and regain traction and then accelerate?
Jeff
