Author Topic: Kiwi Sid's liner  (Read 11484 times)
Offline floydjer
Re: Kiwi Sid's liner
« Reply #30 on: June 27, 2020, 02:30:47 PM »
Yeah Sid...We old geezers need captions. 8X10 glossies with descriptions on the back. JB
« Last Edit: June 27, 2020, 04:29:04 PM by floydjer »
Offline dw230
« Reply #31 on: June 27, 2020, 03:30:22 PM »
There are notes on the back of each picture, turn your monitor around.
DW230
Offline ronnieroadster
« Reply #32 on: June 27, 2020, 03:33:18 PM »
Im trying to figure out the Arm&Hammer Double Duty    :cheers:
Offline racergeo
« Reply #33 on: June 27, 2020, 04:08:52 PM »
  Not to hijack this tread....but my new HOTROD just came and it has an interesting story called "New Concepts for Advanced Land Speed Racing Car Design". Keeping BV racing in the public discussion. Some interesting ideas.   George
Offline floydjer
« Reply #34 on: June 27, 2020, 04:30:34 PM »
DW230
Aah....so THAT'S what it's all about!😀
Offline ggl205
« Reply #35 on: June 27, 2020, 04:57:29 PM »
Kind of reminded me of Arlo Guthrie singing a line from ?Alice?s Restaurant.?
« Last Edit: June 27, 2020, 05:00:18 PM by ggl205 »
Offline Mike Borders
« Reply #36 on: June 27, 2020, 06:39:05 PM »
"with circles and arrows, and a paragraph on the back of each one, explaining what each one was, to be used as evidence against us.  Took pictures of the approach, the getaway, the northwest corner, the southwest corner, and that's not to mention the aerial photography...."    :laugh: :laugh: :laugh:
« Reply #37 on: June 27, 2020, 08:42:23 PM »
Okay, Sid:  Here's how to add notes or comments between the pics:
Go to the Sid's Liner post with the pics, and at the very top/right you'll see the buttons for "quote" and "reply" and "MODIFY".  When you click modify you'll see the post - but it'll look like the attached screen shot -- lines and lines of code instead of the photos.  It's easy to tell where one ends and the next begins (I always leave a double space there), and in that space is where you should click your cursor and start typing your comments for the picture BELOW.
It'll help you keep things straight if you make a note of which pic is which so you known which you're talking about.  Go ahead, give it a try, and the worst that'll happen is that you'll do something wrong and crash the entire site, and London Bridge will come falling down, and it'll turn cold outside and all the diesel fuel will gel.  Don't worry -- I'll fix it tomorrow. cromag
Offline floydjer
« Reply #38 on: June 27, 2020, 09:02:22 PM »
Correct...and a shout -out to the Hokey-Pokey :friday
« Reply #39 on: June 27, 2020, 09:59:15 PM »
That is, after all what it's all about.  :cheers:
Wayno
« Reply #40 on: June 28, 2020, 12:06:46 PM »
Thanks for helping with all this Mate! I'll just let it roll & if anybody is interested I'll answer any questions. This whole build is only about me testing myself, it's not a "look at me" thing so now it's out there we can all carry on with our day.
« Reply #41 on: July 13, 2020, 01:15:38 AM »
I thought I'd filled in some details but that must have been a different dream.
The Engine is a 638" 6 bolt main KB-600 with an 11.250 deck height, Callies crank, dual plug Brodix heads & T&D shaft rockers. Two Electromotive Tech-3 ecu's on a single crank trigger for ignition & driving the Moran injectors. Turbo's are GT6029's & they (4) came off a Detroit 16V-149. Trans is a direct drive billet internals 400 with a modified 4L80E adapter onto a modified NP205 T-case with Chevy & ford output shafts. All the custom shaft's are 300M with Greek Couplers. Front T-case/reverser is built around two 7-1/2" gears from a Liebherr 995 excavator pump drive & there are direct drive/overdrive's in front of both pinions. The front diff is upside down facing backwards & everything has pumps.
Fuel tank is 32 gallons & on CG to not effect balance.
Offline Mr. Schimstock
« Reply #42 on: July 13, 2020, 01:17:58 PM »
Your machine has come a long way since I saw it last!   It's looking really nice.
Sproing, crack, ouch!
« Reply #43 on: July 14, 2020, 06:01:25 PM »
Sid,
I was wondering if you were running AABG or AABF class but with a 32 gallon fuel tank I am sure it is AABF!! I really like your use of the Liebherr gears for your over drive. Off road mining equipment is quality stuff and STRONG! They make their stuff our of the best materials and use the best manufacturing procedures and heat treats, good stuff. (4) hairdryers(?) are you doing turbo compounding?
« Reply #44 on: July 14, 2020, 06:18:43 PM »
"Four hairdryers?"
I understand he's waiting on a permit to open a salon.
