Author Topic: shifting a C4  (Read 2025 times)
Offline Happy Pappy
shifting a C4
« on: December 31, 2019, 04:06:40 PM »
Happy New Year all,
I've been following the recent budfab shifting topic and it got me interested again in shifting my C-4 without a torque converter. Current set up is a simple manual lever starting with N then pushing forward 1,2,3 get through the lights and jerk it back through the gears into N.
So anyhow I started looking again & came across this on YouTube:
https://www.youtube.com/watch?v=JcS96cIUx1c
Looks to me that by using an Arduino control board, 2, 4 way controllers & 2 buttons on the butterfly wheel, One for the N-1,2,3 shift and the other button to slam that dude back to neutral.
Looks like it could be do-able?  Anyone try or see anything like this, maybe even with air switches?
Chris
Chris Campbell
2017 #203 G/GR El mirage record 150.771
2020 #62 C/AIR El Mirage record 180.828
6/21 #62 C/AIR El Mirage record 185.488
9/21 #62 C/AIR El Mirage record 194.450
Re: shifting a C4
« Reply #1 on: December 31, 2019, 06:34:56 PM »
Why complicate the simple system you now have?
Offline Happy Pappy
Re: shifting a C4
« Reply #2 on: December 31, 2019, 07:55:06 PM »
LOL... I know Stan, I just got bored and have never seen this ingenious simple solution of mating a couple of cylinder to make 4 definitive moves.
Also seems like it's getting harder to move in the ever shrinking cockpit... Or maybe it's the ever expanding me ;-)
Chris
Chris Campbell
Offline ronnieroadster
Re: shifting a C4
« Reply #3 on: January 01, 2020, 04:30:33 PM »
Your shift pattern is not very safe. Your jerking the gears in a down shift mode if I read what you posted correctly. If thats true have you ever experienced what happens when you down shift from third to first on a run if for whatever reason you stop prior to getting into neutral?  its not pretty you end up spinning when the rear tires abruptly stop.
 Ronnieroadster
« Last Edit: January 01, 2020, 04:32:40 PM by ronnieroadster »
Offline Happy Pappy
Re: shifting a C4
« Reply #4 on: January 01, 2020, 07:25:37 PM »
Yes for sure that would not be good. So what to do without a torque converter and a C4 transmission. I don't think I am the only one with this combination.
Chris
Chris Campbell
Re: shifting a C4
« Reply #5 on: January 02, 2020, 01:44:24 PM »
Spin?
Well, it is a roadster.
Re: shifting a C4
« Reply #6 on: January 02, 2020, 04:25:47 PM »
Chris
 Its simple the standard shift pattern manual valve body is all you need when your in third gear the next movement would be to neutral. I use a standard pattern manual valve body made by Dynamic to shift 1st, 2nd and 3rd gears to shift each gear I use a transmission cable thats 14 feet long easy to find at Jegs, Summitt and I bet from many others.  I drive a rear engine modified roadster modified the cable shifting makes it so easy and safe.
 Ronnieroadster
Offline Happy Pappy
Re: shifting a C4
« Reply #7 on: January 03, 2020, 06:53:04 PM »
I do not have a torque converter? So how do you start. Get your push while in N then go from N,3,2,1 then run back through the gears, (1,2,3) then N on your way down the course?
Sorry for my ignorance just trying to figure this out.
Chris
Chris Campbell
