SCOTT GUTHRIE REMEMBERS:
50 Years at Bonneville
Chapter #20
Dumpster Divers Start Their Final Attempt.From five years preparation, it was
now down to the next 45 minutes.
Safely into far-end impound, and glancing at my north - bound time slip,
I saw we were almost one mile per hour over the current record.
If I could keep up my speed on the return run home to the west, there might be a record.
A puff of wind could make the difference.
After entering the timing lights at good RPM,
the engine started giving up, and I could again feel it slowing.
It slowed the whole last mile.
Somehow, I had brought enough life from the salvaged rings
that the bike had maintained speed while struggling north down
the timed mile, so I did have a mathematical chance.
I was close to the fourth record and if I was able to manage to
go back down the course without having the abused engine lose
too much speed again, maybe we could do the impossible.
My dream was SO close!
At the turn-around, which would last no more than an hour,
we would be allowed to make NO REPAIRS! I would be allowed
to adjust the carburetors, set the ignition timing and oil the drive chain,
check the valves. Change plugs if needed. NO changing the sprockets.
Putting air in the tires was OK, but NO changing tires.
If I had a flat, we were done!
NO changing piston rings either!
The one-hour time limit for going back on the second
(back-up) run was strict! AND, the clock started to run
from when I STARTED my first run. By not driving to the
impound area, and by having to load the bike into the van,
and then remove it, we were consuming valuable time!
We used the brief turn around to pull out the oiled plugs,
and I installed my last set of new spark plugs. I could only
hope these new plugs would keep sparking for the last three miles.
In those years, there were no auto parts houses in Wendover,
and nobody else at Bonneville used my odd Harley hot plugs.
If that didn?t work, a quick 120 mile trip to Salt Lake City would
have to be made, and waste the day. Besides, if I couldn?t have
working plugs NOW, I would NOT get the hoped-for record.
We might have the chance to re-qualify on Saturday,
but that was a big risk. At Bonneville, you never know
if there WILL be a tomorrow to race.
There could be wind or rain.
Maybe the volunteers will have had enough,
and they would just go home.
Still in my leathers, but helmet and gloves off,
I lifted the bike onto a stand that allowed me to
rotate first the back and then the front wheels for inspection.
Photo. On the return run southwest, I kept up the ?plug-cap?
routine the whole run, three miles with
only one hand on the bars at 150 mph.
Harley Factory does NOT recommend this procedure at 150 mph??. I dipped water from the drink cooler and washed the salt
from the tires and carefully examined the treads for damage.
I did NOT want a tire to ?go down? on this run.
The bike was hard enough to control as it was.
It was quietly ? never publicly - said that there were
occasionally sharp metal objects on the track ? usually
the result of exploding engines ? that were NOT found
by the crews keeping the salt clean and groomed.
I was just being careful.
Some years later, that problem would almost
cost the life of my rider Jason McVicar.
My tires looked good, and the tire pressure was unchanged,
but I had one more problem.
I again had to do some careful planning,
and do it quickly, since I had to run within the next ten minutes.
If I nailed the throttle on the return run, and killed the struggling
rings too early in the run, I would never develop the power
to get the bike up to full speed.
Result: no record.
OR, I could baby the bike, and accelerate slowly and save the engine.
THAT might save the rings, but result in never getting up to a high
enough speed to actually be fast enough to challenge the record.
Again, no record!
The decision was to just do the same thing I had been doing,
and hope that what worked before would work again.
We buttoned up the bike for the return,
and rolled it off the work stand and into line.
The line of vehicles waiting to return was shorter than an hour ago.
There were fewer of us ?going back,? since
some had broken engines on the way east.
Outwardly calm, I sat on the bike waiting the few minutes
for the starter?s gesture. My helmet and gloves on,
and my face shield up.
In a now-familiar motion,
the starter looked down at the salt,
listening to his headphones.
He then looked at my bike and quietly spoke
my racing number into the microphone.
I knew we were close to the start!
After a pause of a few seconds,
the starter looked me in the eyes,
and raised his eyebrows.
Nervously, I nodded my head.
PHOTOS: In the original articles, lovingly published by Wendy at the BONNEVILLE RACING NEWS, there were PICTURES !...It is a little too cumbersome for me with my 75 year old pre digital brain to post those here since it involves photobucket and things like that. IF you go to my facebook account, the pictures are attached to THAT version of these articles..........https://www.facebook.com/scott.guthrie.3154.........
