This is not intended as criticism of anyone's opinion or point of view, and it is not directed toward any specific person. It's just a "brain dump". I do it less often now, as the "brain bucket is nearing empty" . . . . .
I don't know much, but I do know one thing for certain:ANYTHING that impedes fulfillment of "piston demand", in any normally aspirated engine, decreases power produced. It is as simple as that, back to the "air pump" analogy.
Worst example analogy, from an empirical point of view: If the "transfer area" of a flathead engine is completely "blocked", there is
NO FLOW.Increasing the "transfer area" then, increases flow, up to the point of "diminishing returns". Where this point of "diminishing flow returns", intersects with compression ratio could be modeled with various formats, (such as CFD) but in the finish would need to be verified by dyno testing.
This, in and of itself, is
NOT news. This concept is well known and well documented. Re: the Harley work by C. R. Axtell is one source, and there are others. It pays to "dig up" older research and investigate the results. If for no other reasons, than to prevent "re-invention of the wheel" . . . . . . Older engine engineers were not "dopes". Almost without exception, they were very clever and insightful guys who had some sort of limitation placed upon them. Financial, material spec, delivery period, etc. Those guys did the best they could, with what they had. Pretty much the same as today, for engineers who are "passionate" about their work. Physics does not change, it is our understanding of physical application that, evolves, mostly due to "changing of limitations", or perhaps "clarity of understanding".
Applying concepts to various engine types is simple. Any barstool racer can present any theory or opinion. It is the precise, and effective, application of theory, backed up with test data, that is the "difficult and expensive" part. Which is why these things are not done more often, and why persons who "invest" in "testing theories" are less than willing to share their results with the average barstool racer . . . . . .
