I've studied everyone's comments and suggestions and determined I had no ability to optimize Cg and Cp with the previous design. So I decided to take a different approach and repackage everything into a front engine layout as shown in the attachments. I've moved the drive wheels to the rear and designed single wheel suspension steering using a hub center mechanism with dual shocks and hydraulic steering control.
I designed a 50 lb refrigerant intercooler for the intake charge, oil and methanol at the front, and a 30 lb intercooler system for the drive motors and electric controllers at the rear. Those systems will use digital thermostatic expansion valves to meter refrigerant delivery through control channels in the engine management system. Low pressure heated refrigerant will bleed off from the expansion lines after passing through the connected intercooler tanks.
