Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Misc Forums
NON LSR Posting
(Moderator:
Flathead Ford Experts...
« previous
next »
Pages: [
1
Go Down
Author
Topic: Flathead Ford Experts... (Read 2843 times)
floydjer
"There is no duck side of the moon..."
on:
March 28, 2019, 01:39:34 PM »
Anyone know the rationale/purpose behind those rods running from the bellhousing to the front of the block?
Last Edit: March 28, 2019, 01:42:42 PM by floydjer
Re: Flathead Ford Experts...
Reply #1 on:
March 28, 2019, 02:22:49 PM »
If the block doesn't bend the crank won't break?
Hey Jerry, it's almost Friday.
Podunk
Reply #2 on:
March 28, 2019, 03:50:07 PM »
They are right under the exhaust. When the engine runs they will be " hot rods ".
floydjer
Reply #3 on:
March 28, 2019, 09:10:00 PM »
I know Pete....Just hours away from bad puns, silly situational humor and witty reparte`....Or if we want to rest our brains? We can just troll the snowflakes
Jack Gifford
Reply #4 on:
March 29, 2019, 01:30:40 AM »
They remind me of the clutch-anti-chatter rods that some flathead Fords had- maybe just temporarily attached to front of block instead of to front crossmember?
M/T Pontiac hemi guru
kiwi belly tank
Reply #5 on:
March 29, 2019, 01:39:48 AM »
The only time I'd ever seen them back in the day was on truck engines & I assumed they were to stiffen the bellhousing. Never saw any on a pickup or car.
floydjer
Reply #6 on:
March 29, 2019, 08:52:57 AM »
I was thinking truck/industrial or stationary power...I showed that to an "old guy" buddy that worked in an automotive machine shop until he retired in 1985 and he said WTF
Dynoroom
Reply #7 on:
March 29, 2019, 10:53:18 AM »
I wonder if it helps the guy putting the engine together? Turn it around easier & lay it over to set the crank then pick it back up to install pistons etc...
ronnieroadster
Reply #8 on:
March 29, 2019, 11:23:32 AM »
A flathead expert well let me see if I can help. The two rods are called anti chatter rods. When the engine is installed in the chassis the rods go rearward bolted to the bell housing casting in the location as shown in the photo but now pointing rearward so they can be bolted to the transmission cross member. Look closely and you will see the hole in the end of the rod is actually tapered a special bolt was used to attach the rods to a matching tapered shape stamped in the frame cross member. The builder just moved them forward to be out of the way during engine assembly.
ECTA XF/BGRMR Record 179.8561
LTA XF/BGRMR Record 200.921 First Ever Ford Flathead Roadster to hit 200 MPH burning gasoline July 2018
SCTA XF/BGRMR Record 205.744 First gas burning Ford flathead powered roadster to top 200 MPH at Bonneville August 7, 2021 top speed 219.717
SCTA XXF/BGRMR Record 216.131 plus a Red Hat
floydjer
Reply #9 on:
March 29, 2019, 11:37:25 AM »
Indeed....Must have placed them in the holes backward to keep them w/ that engine. Mystery solved.
Jack Gifford
Reply #10 on:
March 29, 2019, 11:36:47 PM »
Well I was at least close! As for the rods anchoring to the
front
crossmember, maybe I'm remembering what some hot rodders did?
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Misc Forums
NON LSR Posting
(Moderator:
