Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Bonneville Salt Flats Discussion
World of Speed-specific stuff
Car Classification
« previous
next »
Pages: [
1
Go Down
Author
Topic: Car Classification (Read 7004 times)
1045
New folks
Car Classification
on:
January 24, 2019, 09:08:37 PM »
2018 was the first year for the car I built on the salt as a B/Classic Gas Coupe . We had a great time both on and off the track. now that I've seen what it's like to go fast out there I'm making some changes to the car to go a little faster, The car is a brick and the engine, which is a hopped up 429 CJ, can't quite over come it's frontal resistance.
I've made some changes to it that would make it a modified classic gas coupe and am in the process of building a 545 inch 460 which would put it in the AA engine class. all that I understand but I'd like to run Time only. Does that need to be on the side of the car like this 1045 AA/MCGC/TO or just marked time only on the entry forms?
Thanks, Mike
Plan ahead, that way you don't have to do anything right now.
Robert W. P. "Stainless" Steele
Re: Car Classification
Reply #1 on:
January 24, 2019, 11:18:58 PM »
Why do you want to run Time Only?
Did you build a class legal car?
Please tell us more
1045
New folks
Reply #2 on:
January 25, 2019, 01:53:29 AM »
The car is evolving, I'm seeing what works and finding out a lot about what doesn't work. At this point I'm not so interested in chasing a record as just seeing what it can do. It may never be competitive but it sure is fun to play with.
What, me worry?
Reply #3 on:
January 25, 2019, 10:20:49 AM »
What are the tech inspection requirements for a car to run "Time Only"?
Regards, Neil Tucson, AZ
RichFox
Reply #4 on:
January 25, 2019, 12:53:45 PM »
I think the point Stainless was making is that it would be simpler to enter a class that you more or less fit in. Tech is for safety items. Being class legal is for record impound. So I believe it will be quicker and easier to just enter a class and run the car,
hoss
New folks
Reply #5 on:
January 25, 2019, 03:18:52 PM »
See what class it fit's, comply with class and engine size and run for a record,,,,,,admittedly coming up a bit short, most do. No use running time only with a class compliant car.
New folks
Reply #6 on:
January 25, 2019, 03:41:17 PM »
As of now the car fits solidly in the modiied classic gas cupe class so that's what I'll do until the next round of modifications. Thanks for your input.
dw230
Reply #7 on:
January 25, 2019, 05:18:48 PM »
On what page of the rule book did you find a class called Modified Classic Gas Coupe?
1045
New folks
Reply #8 on:
January 25, 2019, 07:31:15 PM »
correct me if I'm wrong but the car was manufactured in 1966 which puts it in the classic category, it has an engine swap so gas coupe, and I have covered the headlights. Does that make it modified or altered? Or am I reading too much in to this? I've been reading pages 83 through 88 .
Last Edit: January 25, 2019, 09:46:23 PM by 1045
jacksoni
Reply #9 on:
January 26, 2019, 08:40:03 AM »
With headlights covered it is an Altered. From 1966 it MAY run in Classic but doesn't have to and there are some disqualifiers like non OEM EFI. What Dan is pointing out is some confusion of CATEGORY vs CLASS.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
1045
New folks
Reply #10 on:
January 26, 2019, 12:07:07 PM »
Thanks. Being as I'm a newby I appreciate all the input.
kiwi belly tank
Reply #11 on:
January 26, 2019, 02:08:30 PM »
I don't know about category but it has gobbs of class!
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Car Classification
