Author Topic: The Green Fiend 100cc A/G and A/F 2019 build  (Read 10669 times)
Re: The Green Fiend 100cc A/G and A/F 2019 build
« Reply #30 on: February 01, 2019, 11:08:43 AM »
Is there a wind tunnel near you?  This testing can be a big help.
Offline skidpupRandD
« Reply #31 on: February 02, 2019, 12:08:03 PM »
Im in Southern California so im sure there is one, but Im not sure I could fund going out there.
Offline Harold Bettes
  • Firebase High Country
« Reply #32 on: February 03, 2019, 12:51:39 AM »
See if you can get in touch with Joe Katz at the University of San Diego Mechanical Engineering Department. He is a gearhead and plenty savvy on aerodynamics as well. Bet he could give you some guidance that would be worth a phone call. Then maybe you could do lunch,too. A guy has to eat!
There are also guys at Caltech in Pasadena.
Good Luck.
Regards,
HB2 :-)
« Reply #33 on: February 03, 2019, 01:10:20 AM »
Good Luck.
Regards,
HB2 :-)
Thank you!
Offline Koncretekid
« Reply #34 on: February 03, 2019, 10:00:26 AM »
Mikey,
Here is a handlebar suggestion.  It uses standard clip-on clamps with cutoff standard handlebars.  It's comfortable and fully adjustable.  The only thing you should do if you choose this way is to "stake" the bars  when they feel best by drilling and tapping machine screws thru the clamps into the bars to prevent them from rotating downward under pressure from your arms.
« Reply #35 on: February 03, 2019, 04:50:12 PM »
Mikey,
that is how my bars are currently positioned, only lower than the bottom triple tree.
Offline Koncretekid
« Reply #36 on: February 03, 2019, 05:58:01 PM »
You can do that in "A" Class.  My little Triumph is an "M" class, so handlebars and seat must be above the "top of the rear tire" at SCTA events.  I'm not sure how they measure that at the front of the bike, but I think it best to keep them above the top of the front tire as well.
At BMST, the rule states above the top of the rims, so is a little more lenient.
« Last Edit: February 03, 2019, 06:00:39 PM by Koncretekid »
« Reply #37 on: February 03, 2019, 11:39:17 PM »
Oh ok, building an rz350 too, will be an M bike, I will keep that in mind. Thank you.
