Author Topic: Bosch 2200cc injectors!!!.  (Read 8510 times)
« on: December 03, 2018, 04:15:21 PM »
Are 8 enough for my 351C?.
George has 16. :-D :-D :-D
Offline n49racer
  • Faster Faster
Re: Bosch 2200cc injectors!!!.
« Reply #1 on: December 03, 2018, 05:27:36 PM »
What Fuel?
B/STR  209.97 best
B/RMR  248.45 Record Holder 2012
B/FRMR  248.85 Record Holder 2012
2 club member 2012
Offline Dynoroom
« Reply #2 on: December 03, 2018, 05:34:52 PM »
Depends on power & fuel...
BTW, George has 18 injectors. 2 set of electronic & 1 set of mechanical.   8-)
Offline Interested Observer
« Reply #3 on: December 03, 2018, 06:42:57 PM »
In order to obtain increased capacity, a certain tuner, whose name appears above, has used propane injectors (which may be more economical than especially large gasoline types).
« Reply #4 on: December 03, 2018, 07:13:12 PM »
  HP X BSCF [.55 -.65] divided by # of injectors x duty cycle  not more than .9O %  result in lbs.
  from Holly.con   EFI  go to Dominator ECU unit scroll down, lots of different questions answered.
  WRONG directions, but the formula is there somewhere under tech :-D
« Last Edit: December 03, 2018, 07:44:32 PM by jl222 »
« Reply #6 on: December 04, 2018, 12:13:35 AM »
I just saw a photo and thought he had 2 per cylinder. Thanks Michael.
« Reply #7 on: December 04, 2018, 02:21:38 PM »
  What ECU are you using?
« Reply #8 on: December 04, 2018, 08:30:07 PM »
  I always wondered what CC to lb was divide CC BY 10.5  2200 BY 10.5 = 209.5 LBS PER HR.
  Now got to find formula for lbs per hr to hp :-P It's in the Holly EFI site.
« Reply #9 on: December 05, 2018, 12:53:27 AM »
Fueltech FT350.
My expert says it's fine for my application.
« Reply #10 on: December 06, 2018, 09:50:11 PM »
   Ok found it   injector size x duty cycle divided by BSFC X # of injectors
                          209 x .8  divided .5 =334.4 hp per cyl x 8 = 2675.2 hp
     Formula means injector size will support that much hp.
« Reply #11 on: December 07, 2018, 05:37:19 AM »
Thanks so much. To be honest, all Greek to me but if that's calculated on
what I have then no problem. I only need 40% of the 2675!!!!!.
ONLY!!!!!?????? :-D :-D :-D :roll:
JL100%. :cheers: :cheers: :cheers:
« Reply #12 on: December 07, 2018, 12:21:29 PM »
  The 2200 might be to big.
    jl222
Offline robfrey
    • carbinitelsr
« Reply #13 on: February 16, 2019, 09:57:20 PM »
I liked running ethanol. It has a very big tune window. 2200 cc will be fine.
I always run the biggest injectors that I can get away with. As long as you can get it to idle, it will more of a “timed” injection than smaller injectors.
I hear great things about FuelTech.
How much boost do you plan on making?
Rob Freyvogel
#496
AA/BFS
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
« Reply #14 on: February 17, 2019, 12:10:22 AM »
Rob, I have Nassen Padyachee handling the EFI, turbo and Fueltech system.
He's the local agent and held the record for the fastest FWD drag car in the Southern Hemisphere for 9 years.
He gets flown out to the States on a regular basis for NHRA events due to his skill on tuning Fueltech equipped cars.
All this new stuff is beyond me but Tom says I need 1000HP to reach 300 with what I have.
The guys tell me what to build/have made and I go with their advice.
I'm a good assembler but not an engine builder.
Nassen is the nicest guy you'll ever meet and we have a barter deal going. I make Carbon parts for him and he supplies
BOVs and wastegates etc. It saves on spending. My budget is severely limited. My friend and Carbon supplier Gebi gave
me a roll of some very good Carbon for Christmas.
The Flyer should be called the "Miracle Machine". :cheers: :cheers:
