Author Topic: Heavy duty main stud girdle.  (Read 5733 times)
Re: Heavy duty main stud girdle.
« Reply #15 on: November 08, 2018, 12:10:23 AM »
It's been a while  :roll: but the main cap register in the block was left the same & the outer stud holes were vertical like a BBC & we only did the center three. I believe the stud kit we used was 4 bolt BBC. You can probably come up with a machinist to whittle some out for you & then align bore the whole mess.
Build a crank scraper in your pan, it's a must have item for the long haul & fix the crappy Clevo oil supply problem.
Offline floydjer
« Reply #16 on: November 08, 2018, 08:43:27 AM »
I took a quick look at that girdle...Then glanced at my Index 745 and my arms started to hurt. Thank you to whoever invented the CNC machining center. :cheers:
« Last Edit: November 13, 2018, 10:53:35 AM by floydjer »
« Reply #17 on: November 08, 2018, 09:28:57 AM »
x 2
« Reply #18 on: November 08, 2018, 10:40:17 AM »
Sid, that's what my mate Derek keeps telling me.
4 bolt mains are rare here in SA but I can find the material
if I know what to get?.
Thanks for always telling it like it is. :cheers: :cheers: :cheers: :cheers:
Mike;
I'd use 2024-T3 if you can find it. A 4" wrought plate might not be T3 but something close to that heat treatment.
« Reply #19 on: November 08, 2018, 11:03:06 AM »
Thanks everyone. Going to can the girdle idea and go with 4 bolt mains.
Sid knows the Aussie 351C and the blocks are way tougher than the thin wall
US casting. The Oiling thing is a done deal. First thing I sorted. :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
BTW Neil, I checked the data sheet on that material. Greek to me but I know someone :wink:
« Last Edit: November 08, 2018, 11:08:24 AM by tauruck »
« Reply #20 on: November 08, 2018, 04:45:26 PM »
2024 is aluminum, I'd be inclined to stick to steel on an iron block.
« Reply #21 on: November 08, 2018, 04:48:04 PM »
D'oh... you're right, Sid. I'm too used to aluminum blocks. (Lame excuse)
