Tom,
Don't even think about taking the air through the radiator core, adde heat, potential inlet restrictions, not a good idea.
Here is another thought, looking at the rules it states that a street roadster may have a hood scoop per section 4.R which allows you to have a scoop up to 11 inches above the hood. It does not state that the scoop has to be on the center line of the hood, so how about centering the scoop in front of yourself and make its shape to help shroud you and your roll bar. You are already a big "blivit' on the frontal area of your roadster, use the air scoop to direct the air around you and not increase the frontal area of your car. The obvious thing that this brings is you have a scoop that doesn't contribute to additional frontal area, and it helps clean the air up going around you. The not so obvious things are that now you have an air plenmum that is sealed to your carb top that has huge volume and this will assist in reducing the air inlet speed to a minimum and recovering the maximum amount of pressure from the high velocity air that is coming into the inlet, i.e. "a little additional air pressure at the carb inlet never hurts!!!!"
