Author Topic: Vesco Turbinator goes sideways, up on two wheels at WOS last day.  (Read 7153 times)
Offline Ricco
  • Team Vesco Crew
Here's an unpublished car cam video of the Turbinator from WOS 2018.  Once we got our backup run done on the 482 run, the engine got turned up to 108%.  (We are still working on the traction control.)  It was a little too aggressive and Dave had his hands full.  Pay close attention after the 35 second mark on the video.  Watch the horizon too.  The number in the bottom right is wheel spin in % of actual speed.  He aborted at about the 1.5 while sideways and on two wheels, in the mid 300MPH range, with 25% wheel slip (~100MPH slip).  Tire surface temps his 375, and we burned all the rubber off all 4 tires.  The data from that run was used to fine tune the software, which in turn resulted in great performance at the Finals.  Thanks to Ken Braccio from Advanced Turbine Services, and his competent engineers Eldon, and Jeremy, the turbine magicians behind the curtain.
https://youtu.be/jEB9QjOaGBk
Ricco   (AKA Rick Kunze)
Rick (Ricco) Kunze
Crew/Driver, Vesco 444 Streamliner
Offline jimmy six
Re: Vesco Turbinator goes sideways, up on two wheels at WOS last day.
« Reply #1 on: October 13, 2018, 06:49:46 PM »
whoops!
Offline Interested Observer
« Reply #2 on: October 13, 2018, 07:31:14 PM »
What is used as a reference speed when calculating wheel spin?
Offline Ricco
  • Team Vesco Crew
« Reply #3 on: October 13, 2018, 08:05:16 PM »
We have two separate GPS systems, one is Mil spec and if I'm not mistaken runs at 50 Hz.  The two are used to determine vehicle speed, and that is compared with driveshaft speed.  A math channel takes care of the heavy lifting.
Hope this helps.
Ricco
Rick (Ricco) Kunze
Offline Jack Gifford
« Reply #4 on: October 14, 2018, 12:24:23 AM »
Data acquisition is priceless.
Great driving ranks right up there too...
M/T Pontiac hemi guru
Offline STICK777
« Reply #5 on: October 14, 2018, 05:00:18 AM »
I adore ALL these guys to just jump back in after they went through scary moments during a pass (counting the events this year).
David Spangler went even faster after that and eventually hit 503mph exit speed, Danny Thompson set his AA/BFS record,
the driver of the Dauernheim Bigelow Lakester had a very scary moment during Speed Week and went out again... RESPECT.
« Reply #6 on: October 14, 2018, 10:57:50 AM »
Hey Stick... looks like you are close to Pork Pie, you should look him up to talk about Salt Flats racing....
And Congrats to Rick, Dave and crew... what a year
Offline STICK777
« Reply #7 on: October 14, 2018, 12:20:33 PM »
Dang, that's true... about 40 miles from here so basically just around the corner.   :roll:
Offline Frank06
« Reply #8 on: October 14, 2018, 12:45:19 PM »
Excellent car control!
Sent from my MotoE2(4G-LTE) using Tapatalk
E-Racer
Offline PorkPie
  • think fast.....always
« Reply #9 on: October 14, 2018, 01:54:07 PM »
....going on two wheels is not new for me..... :roll: :roll: :roll: :roll: :roll: :-D....if you meant talking about salt flats racing, Stainless....or :cheers: :cheers: :cheers: :cheers:
« Reply #10 on: October 14, 2018, 07:40:21 PM »
wouldn't that be a "HELLO moment"   :-D
« Reply #11 on: October 14, 2018, 10:44:34 PM »
More like a "OHELLNO" moment
Offline stay`tee
« Reply #12 on: October 15, 2018, 12:31:50 AM »
I would say that it was one of those situations at the time, that experience/reflexes delt with, in hindsight, the comment as always " I didn't think it was as bad as that"  :-)
Offline Ricco
  • Team Vesco Crew
« Reply #13 on: October 15, 2018, 04:23:59 PM »
HEY Pork Pie!!  Where have you been?
Haven't seen you out there in a while.  Folks were asking about you this year.
Rick (Ricco) Kunze
Offline Ricco
  • Team Vesco Crew
« Reply #14 on: October 15, 2018, 04:33:26 PM »
It appears that he only went up on two wheels once.  But Dave said it felt like 2 or 3 times.  The camera shake and body flex could have hidden it.  If you watch closely starting around the 35 second mark, focusing on the G meter and the horizon, you can see that there were some periods where the side load (G's) exceeded that which resulted in the final slide and tilting of the horizon.  If he wasn't on two wheels, he was at least off the rubber.
Rick (Ricco) Kunze
