Author Topic: Thinking about next year  (Read 3468 times)
Offline Doc B.
    • Bottlehead Corp.
« on: September 06, 2018, 12:42:40 AM »
on my way home, of course.
Coupla questions-
1) Is 750 P-PB a recognized classification?
2) Is fuel injection in place of carbs allowed in M-CG? M-CF? The engine rules for CG and CF are specific about using OEM heads, cylinders and crankcases but there does not seem to be any other restriction in the description aside from the overbore limit.
Offline donpearsall
    • http://soundappraisal.com
Re: Thinking about next year
« Reply #1 on: September 06, 2018, 11:21:41 AM »
YES - 750 P-PB is a recognised class. I entered my Kawasaki GPZ 750 a few years ago as there was no existing record for it (still isn't). The GPZ is a factory turbo bike, kind of rare. I did not get the record as the bore was measured to be larger than factory bore. I disputed that it was, but still did not get the record.
As for replacing carbs with fuel injection, if the rules do not specifically say you can't, then you can.
Offline Doc B.
    • Bottlehead Corp.
« Reply #2 on: September 06, 2018, 02:26:37 PM »
Thanks Don, interesting to hear about the GPZ750. It appears that some other factory turbo bikes are just a bit over the displacement implied by their model number and they would get bumped up a class. Re the FI, that's what I would assume, just wanted to hear if anyone had ever been told no.
Offline Old Scrambler
  • Going Fast - Slowly
« Reply #3 on: September 13, 2018, 09:16:35 PM »
Doc..............good to meet you in impound :-) :-) :-)
It sounds as if the salt has gotten to you.............
