Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Bonneville Motorcycle Speed Trials
Bville Motorcycle Speed Trials Rules Questions
(Moderator:
Fuel Shut-off at Handlebar?
« previous
next »
Pages: [
1
Go Down
Author
Topic: Fuel Shut-off at Handlebar? (Read 6112 times)
Old Scrambler
Going Fast - Slowly
on:
August 04, 2018, 07:08:10 PM »
Been running in Gas classes.........what type of fuel shutoff controls are available and where do I get a system?.............or are they really needed if I run gasoline while in a fuel class?
donpearsall
Re: Fuel Shut-off at Handlebar?
Reply #1 on:
August 04, 2018, 07:28:56 PM »
If you run in the fuel class, you have to have the handlebar fuel shut off. Doesn't matter what fuel you actually use. There are lots of devices to do this. I bought a fuel solenoid from Amazon for $15 that is normally closed so energizing it opens it, and de-energizing it closes the fuel supply. Or there are some ways to do it mechanically with cables. But doing it with a solenoid it very simple.
https://www.amazon.com/gp/product/B00APDNPXG/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Old Scrambler
Going Fast - Slowly
Reply #2 on:
August 05, 2018, 01:39:36 AM »
Thank you, Don
generatorshovel
Reply #3 on:
August 05, 2018, 02:33:52 AM »
Make sure that the shutoff valve you choose has Viton seals, they will handle anything wet , including alcohol, "normal" rubber seals will not. Also, be aware there are pressure feed types, & gravity feed types
Tiny
Tiny (in OZ)
Reply #4 on:
August 05, 2018, 02:22:23 PM »
Pingel makes a spring loaded "guzzler" fuel cock that operates by a cable to a lever on the handlebars. One has been on my bike for years with no problems. I run non-event gas in the fuel class, too.
Old Scrambler
Going Fast - Slowly
Reply #5 on:
August 05, 2018, 06:32:18 PM »
Thanks, guys..................I ordered 2 electric units for my twin-tank gravity setup.
Old Scrambler
Going Fast - Slowly
Reply #6 on:
September 13, 2018, 09:11:45 PM »
Follow-Up:...................the electric units had 'tiny' flow volume.............so Dave made custom units that operate with a split-cable adapted from a 1960s Honda twin. They work great
Koncretekid
Reply #7 on:
October 25, 2018, 11:04:11 AM »
Dennis,
Can you post a photo of Dave's modification, including the handlebar control and the valve control? I presume the cables are just being used to turn off the fuel valves.
Bookfla
Reply #8 on:
October 25, 2018, 12:51:05 PM »
I have run the Pingel cable type shutoff on Nitro Fuel Drag Bikes for years without issue. Nice thing about the Pingel valves is you can design the different component/parts (opening size, hose barb, AN fitting etc.) of the valve to fit your need.
Old Scrambler
Going Fast - Slowly
Reply #9 on:
November 06, 2018, 08:19:09 PM »
Tom......I'm in Florida and won't return to Wisconsin until Summer
Two tanks with petcock handles in opposite directions...........required an alloy fitting with a set-screw to each handle........cable pulls handle in opposite directions via a small lever similar to a compression release unit..........Yes, only required to turn the fuel off.
Pages: [
1
Go Up
« previous
next »
Landracing Forum
(Moderator:
