Author Topic: 9" Ford 2.56:1 ratio 28 spline Ring and Pinion.  (Read 1486 times)
Offline R1150GS
« on: April 09, 2018, 11:28:23 PM »
Hi all,
I am new here to your board, but have out to the salt many times as a spectator.  I tend to be out on the motorcycle days.
A friend of mine has a gear set that may interest the group...
Ford 9"  ratio is 2.56:1 (16 tooth pinion, 41 tooth ring), the pinion has a 28 spline input.  This gear set shows that it has been installed and run for a few miles, but removed shortly after.
The gears are as new.
If there is any interest I can get a few photos for you...  in the box they came in.
Best Regards,
Jim
Offline 8
Re: 9" Ford 2.56:1 ratio 28 spline Ring and Pinion.
« Reply #1 on: April 15, 2018, 04:03:25 PM »
Can you post pictures, and price ?
Offline jimmy six
« Reply #2 on: April 16, 2018, 02:30:52 PM »
May not be a Ford but aftermarket. Fords were usually 2.47. Could be one used by NASCAR since they had made many "unheard of" ratios. Pontiac 57-63 did have a 2.56 and were very similar to the Fords in appearance. A set got me in the B'ville 2 club.
