Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Bonneville Salt Flats Discussion
Build Diaries
(Moderator:
Engine coatings
« previous
next »
Pages: [
1
Go Down
Author
Topic: Engine coatings (Read 2737 times)
handyguy
BANTAM FOURPLAY
Engine coatings
on:
March 26, 2018, 11:16:03 AM »
Weekend project using Cerakote coatings , ceramic (oven cure ) , Microslik (air dry ) for '37 Austin 48 cu. in. flathead in my '40 BANTAM STEVE
sofadriver
Re: Engine coatings
Reply #1 on:
March 26, 2018, 11:27:24 AM »
Interesting but I looked at their site and they say nothing about heat or chemical resistance
Mike in Tacoma
Bike #833
handyguy
BANTAM FOURPLAY
Re: Engine coatings
Reply #2 on:
March 26, 2018, 11:39:50 AM »
There info initally is firearms , engine info is on there somewhere !! STEVE 520 591 6318
Re: Engine coatings
Reply #3 on:
March 26, 2018, 11:43:19 AM »
I really like the port split aspect of the intake - should minimize cylinder robbing,
provided
you're still getting enough overall flow - although 48 CI shouldn't require much.
What CR are you at with this piston/head combination?
"Problems are almost always a sign of progress." Harold Bettes
Well, I guess we're making a LOT of progress . . .
kiwi belly tank
Re: Engine coatings
Reply #4 on:
March 26, 2018, 03:51:58 PM »
Does it still run the 2 bearing crank?
handyguy
BANTAM FOURPLAY
Re: Engine coatings
Reply #5 on:
March 27, 2018, 12:15:04 AM »
C/R about 9/1 ,, (2) 1 1/4 S/U carbs ,, intake should help .. Crank is 2 main billet . Steve
Re: Engine coatings
Reply #6 on:
March 27, 2018, 01:15:50 AM »
Well, I can't speak to the coating method - I sent my pistons out for a service to do it, and I hope what you've got works - but a 48" Austin 4 popper with a pair of HS 2s is right in my wheelhouse.
How are you gearing it, and what are you using for a transmission?
Will you be able to make Speedweek with it this year?
Good luck on this build!
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Build Diaries
(Moderator:
Engine coatings
