Last year, our 1968 Camaro, which had run 243+ in the last mile at Bonneville in 2012, ran 249+ TWICE in the middle mile at Lake Gairdner on Thursday. We had expected it to run less than 240, because of the higher air density at the Lake Gairdner vs Bonneville venue. The track was a little moist and loose on Tuesday, but after the rain on Wednesday, and high winds on Wednesday night, it really tightened up. We run a 600 cu in BBC that produces nearly 1000 hp on race gas. More often than not, we encounter some wheel-spin, but not on that Thursday. If you look at the MTOD video, you'll see two perfectly formed white roostertails of salt coming off the rear wheels. It was hooked up.
That salt was so good, there was not even a pressure-ridge that I could find on the racecourse. From all reports, it might be even better this year.
So, good luck Target 550. Betting on 480 if you avoid breaking.
