Author Topic: Simpson Arm restaint ... Does it meet the new rule?  (Read 34454 times)
Offline jacksoni
Re: Simpson Arm restaint ... Does it meet the new rule?
« Reply #60 on: March 13, 2018, 03:16:22 PM »
Just and FYI, I have Stroud restraints sown on the suit. Bob fixed me up with new "legal" 3-bar tethers for 30 bucks.
  Are you sure the sown on location will meet the rule which if I read this correctly is now at the wrist?
As posted above rule says," NON sewn in restraints must be at the narrowest part of the arm" (wrist).
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline NathanStewart
« Reply #61 on: March 13, 2018, 03:51:09 PM »
Mine are the same as Mikes pics. actually better with the steel attaching point. I am showing up in may with these. Someone official needs tho straighten this $hit out and stop all the spectulation
Brian, yours are not the same as what Mike posted.  You have the exact same ones I do with a slip adjuster EXCEPT that a 3 bar has been added on.  You see that little fabric tab that's on the end of what you're calling the attaching point?  That's for releasing the adjuster to loosen/lengthen the tether.  I don't think I'm reaching too far but it looks to me that all they did was just throw on a 3 bar adjuster to lock down the tail end of the tether.
El Mirage 200 MPH Club Member
Offline thundersalt
« Reply #62 on: March 13, 2018, 03:57:54 PM »
Then that makes them legal
916 REMR
« Reply #63 on: March 13, 2018, 04:06:48 PM »
That's good news for me if that's true.  I'm confirming on my end.
Offline thundersalt
« Reply #64 on: March 13, 2018, 04:49:02 PM »
phuq it!! I just sent them back with a pic of yours Nathan. :-D :cheers: better safe than sorry
916 REMR
« Reply #65 on: March 13, 2018, 05:07:24 PM »
Well don't jump too far ahead... let me see if the added 3 bar is acceptable or not.  Honestly that's what I had thought about doing to the DJ restraints I already have but wasn't sure if it'd fly or not.
Offline thundersalt
« Reply #66 on: March 13, 2018, 05:11:35 PM »
I've been texting with Big Ben and he thinks mine will be ok . He just informed me he doesn't make the ones you pictured any more.
916 REMR
Offline Buickguy3
« Reply #67 on: March 13, 2018, 09:39:44 PM »
  I got the ones like Sumner posted from Deist. Took a while to find the proper part number to get them ordered but I was able to get them from Jegs. Couldn't find anybody else.
                   [America]
Offline deep in debt motorsports
« Reply #68 on: March 14, 2018, 09:50:44 AM »
Well i still cant see why my new G-Force #4087adubk wont work?3 bar adjuster and i only use the attachment from belts to my sewn in rings on my sleeves.I do not use the arm wraps,(not mandatory per rules if I am reading correctly). Cant post a pic,sorry
#327 C/GR
« Reply #69 on: March 14, 2018, 10:49:17 AM »
That sure looks like a welded ring on one end to me and the quick latch from my dog's leash on the other.  I think it's time to spend $50 and get some better stuff.  The arms you save could be your own.
« Reply #70 on: March 14, 2018, 11:11:09 AM »
Here's what I know right now.  The Deist restraint meets the letter of the rule to a tee.  Simply adding a 3 bar to the loose end of a quick adjust type restraint doesn't exactly meet the letter of the rule.  I think there's some discussion going on as to whether or not there's a enough grey area fuzz around the wording of the rule to allow an added 3 bar to be acceptable.
The Deist part number is 60019.  Google results for that come up with two relevant results - one is the Deist catalog (which is showcasing SA95 helmets) and the other is some performance shop with an old outdated website that may have stocked these 10 years ago.  Someone I talked to says you can get the 60019 from Deist right now and then Brian says that Ben from DJ is saying "they" don't make them any more.  As best I know it, the 60019 from Deist, if it can be found, is possibly the only restraint that meets the rule as intended right now.
Don't freak out yet... I'm still digging.
« Reply #71 on: March 14, 2018, 01:03:24 PM »
thanks for posting,$50 is a non issue,the way I read the rule is it is only talking about adjusters,but I must be wrong.Thanks for info and I look forward to getting correct parts #s so I can place my order!
#327 C/GR
Offline Joe Timney
    • Delaware Chassis Works
« Reply #72 on: March 14, 2018, 05:22:17 PM »
Joe- have you had any feedback from Stroud or other suit/harness mfg's?
[/quote
Neither SFI or Stroud Safety had heard about the problem...interesting!
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
Offline ronnieroadster
« Reply #73 on: March 14, 2018, 09:14:55 PM »
Located the Deist Safety 60019 Arm restraint at Jegs for $40.00 now the question is should we buy these?
 Ronnieroadster
Offline Rcktscientist
« Reply #74 on: March 14, 2018, 11:49:42 PM »
I have Deist arm restraints built into my -20 gloves, love them. I have a pair that is a little small for me if anyone's interested.
