Author Topic: UK Lakester build G/GL  (Read 290495 times)
Re: UK Lakester build G/GL
« Reply #285 on: April 07, 2019, 02:00:38 PM »
Nugget Mate! 8-)
The cheap way to move secondary water to another tank is a bilge pump, 500-gph for 20 bucks from Fleabay is hard to beat. You can even afford a spare at that price!
« Reply #286 on: April 07, 2019, 08:14:01 PM »
Nugget Mate! 8-)
I used two in our ice water intercooler...
http://purplesagetradingpost.com/sumner/Hooley%202013/13%20-%20construction%20menu.html
Have three in the boat  8-)  .  The top two flow way more than the bottom one and were a lot more expensive than $20, but a $20 one like I used in the intercooler tank or what Sid is talking about move a lot of water,
« Last Edit: April 07, 2019, 08:17:43 PM by Sumner »
Offline Lemming Motors
« Reply #287 on: April 08, 2019, 09:21:55 AM »
Thanks guys. When I first saw the bilge pump reference (on my idiotPhone) I got nervous - I thought SW was when the flats dried out, not when they were flooded but then I clocked the reference to shifting water from tanks; I like he annotated pictures too though having three in a boat is either extreme conditions or redundancy or a leaky boat. As long as the leak is not at the end of the boat I am sitting at I am okay.
I am still exploring (cost effective) ways to get a rad in a tank; I had a minor light bulb moment when I realsied a specialist made me two fuel tanks in alloy for the Lotus Europa for less than the rad people were going to charge for the water tank so I have sent an email - I could do it in fibreglass but there is a cost vs. time equation here too.
Just a squeeze.
« Reply #288 on: April 08, 2019, 11:46:14 AM »
Aluminum is more desirable, it'll radiate heat, fiberglass will insulate.
« Reply #289 on: April 08, 2019, 03:09:51 PM »
John,
Looking through my "junk" and I have a Harrison heat exchanger that has -10 fittings and is approx. 13.75" wide x 9" tall x 3.5" thick. I can throw it in the box with the steering if you want. $50
Pic below.
Offline ronnieroadster
« Reply #290 on: April 08, 2019, 05:42:45 PM »
John, I'm looking at the D2904 for my car. They are 4". The D1445 is 2.5". I think that's what Ronnie was referring to.  :cheers:
P.s; Was that "Rockin' Rochen"? (ouch)
Wayno
[/quot
 Hi John
   Wayno has the info correct I run the Goodyear D2904. The first tire I ordered was the D-1445 but it was way to light duty for what were doing I sent those tires back and ordered the D-2904.
    Ronnieroadster
« Reply #291 on: April 09, 2019, 04:59:07 AM »
Tyre advise noted, thankyou - I will order the wider section D2904's for the front. Many thanks for the 'catch'.
Just a squeeze.
« Reply #292 on: April 09, 2019, 09:09:48 AM »
I ordered mine yesterday from Summit. They are to arrive tomorrow.  :-D
Wayno
« Reply #293 on: April 09, 2019, 11:44:24 AM »
Wayno - that was not kind  :-D
If I get them ordered they will take weeks to reach me.
Just a squeeze.
« Reply #294 on: April 09, 2019, 12:00:57 PM »
I'm a bad man.  :-D  :cheers:
Wayno
« Reply #295 on: April 09, 2019, 06:33:41 PM »
Wayno
Stop teasing the $hit outa the foreigners Wayno! :evil:
« Reply #296 on: April 09, 2019, 07:10:25 PM »
Sid, I really wasn't trying to tease 'em.  :roll:  Do I still get credit?  :?
Wayno
« Reply #297 on: April 09, 2019, 08:22:59 PM »
Wayno i think to make things right you should pick them up for John and hand deliver them. Two small tires should be fine as carry on luggage.   :cheers:
« Reply #298 on: April 09, 2019, 11:19:49 PM »
Ronnie, that's a splendid idea.  :cheers: Did you need my address so you can send me the tickets?  :lol:
Wayno
« Reply #299 on: April 10, 2019, 01:09:03 AM »
Ah you flathead guys! :mrgreen:
