Forum's been "upgraded".
Things will look a bit different.
A *few* posts might have gotten lost in the crossover.
PM bobc with problems, or post in "Website Suggestions".
Author Topic: Oil filter crossover  (Read 2141 times)
Offline dlra600
« on: December 30, 2017, 12:55:34 AM »
I have a System 1 remote mount from my drag racing days.I think the screw on thread is 1" x 12tpi.I have wire scavenge filters in the return lines to stop rocks & small animals from eating my pump,so I would like to use a Wix type filter for the small stuff before it goes in my engine.Does anyone have a filter# that will fit,rather than buying another complete remote mount deal.
Thanks in advance,Ian
Offline mtiberio
  • El Mirage M-PG 1000cc record, 141.693
Re: Oil filter crossover
« Reply #1 on: December 30, 2017, 08:49:16 AM »
Some tpi info here: https://motorcycleinfo.calsci.com/FilterXRef.html
More than just threads, bypass pressure important as well
Offline n49racer
  • Faster Faster
« Reply #2 on: December 30, 2017, 03:47:32 PM »
The WIX I use is 51222R  this filter is the same as  the big HP6 Fram
ted
B/STR  209.97 best
B/RMR  248.45 Record Holder 2012
B/FRMR  248.85 Record Holder 2012
2 club member 2012
Offline Jack Gifford
« Reply #3 on: December 31, 2017, 12:59:16 AM »
Are you aware that System-1 quit making the original style filter systems a while ago? I had a devil of a time getting my hands on a 75 micron element (for return to drysump tank). Although System-1 said they still have some old-style elements, they do not sell directly to consumers. And since they no longer support the old part numbers, most distributors (Summit, etc.) can't get these old elements. I finally convinced a local retailer to call them and get one for me. [new-style elements are totally different dimensions]
Note: I was referring only to the original filter mounts with the ribbed aluminum housing. I don't know about their other types of mounts.
« Last Edit: December 31, 2017, 01:01:50 AM by Jack Gifford »
M/T Pontiac hemi guru (or does guru status expire after 30 years?)
Offline dlra600
« Reply #4 on: December 31, 2017, 01:17:32 AM »
Jack,I have the remote mount & the ribbed filter,but I was hoping to find a disposable filter that suited the remote housing.
Also,when did my stuff get so old?
Offline deep in debt motorsports
« Reply #5 on: December 31, 2017, 12:27:04 PM »
Do you guys have pics,not sure of what filter in question?Just for my own edumacation.
Thanks
#327 C/GR
Offline dlra600
« Reply #6 on: December 31, 2017, 09:10:27 PM »
Never tried to post a picture before,the message says the file is too large,what do I need to do?
Offline dlra600
« Reply #7 on: December 31, 2017, 10:50:52 PM »
tried again
« Reply #8 on: January 01, 2018, 01:16:42 AM »
Yeah, that's the obsolete style System-1. I don't believe there is any disposable filter that would give the correct oil routing with that, so you're stuck with using System-1 elements. Perhaps you'll prove me wrong- for your sake.
Caution: when shopping for System-1 elements, be advised that they used almost identical part numbers for the new style elements. So don't buy based on just the part number- you need to match dimensions. I learned this by buying one from Summit and having to send it back.
Also- you may already be aware- that elements were available in a variety of screen sizes. At least in 75 and 45 micron, and I think some finer sizes.
As for when these "got so old"... I'm not sure. I think it was about a year ago.
« Last Edit: January 01, 2018, 01:24:55 AM by Jack Gifford »
Offline dlra600
« Reply #9 on: January 04, 2018, 08:56:19 PM »
Thanks Jack & Ted
