This is a C4 transmission and all of the accessories taken out of a land speed car. The transmission was just rebuilt (0 runs) and includes a manual/reversed valve body, close ratio gear set (2:46/1:46/1:1), a direct drive (i.e.: in place of the torque converter), an SFI Spec 4.1 trans shield, a deep oil pan, a flat-o-matic adapter (it went on the back of a flathead), an 8BA bell housing (been cut on - see pics), a flex plate, B&M shifter with the cable, Lokar flexible dipstick tube, and an oil cooler. I will even throw in a torque converter that I used many moons ago with it - although I cannot remember what stall speed it is.
Basically everything here is built, balanced, and could be hooked behind your flathead or other race motor and used immediately. $1800
Brian
(707)280-8305
