Author Topic: Rear wheel spacer question  (Read 6485 times)
Offline ronnieroadster
« on: December 16, 2017, 04:50:56 PM »
  Would anyone know if wheel spacers are allowed at Bonneville? The project Im working on needs another 3/4 inch of space so the rear tires do not rub the inner body surface. Longer studs and a properly machined spacers will cost a lot less than custom built wheels so the reason for the question. No mention is made in the rule book 2.G Wheels or on the inspection sheet.
 Ronnieroadster
Offline RichFox
Re: Rear wheel spacer question
« Reply #1 on: December 16, 2017, 05:31:59 PM »
I have used wheel spacers at Bonneville and nobody ever noticed or said anything about them. But I never used 3/4 inch spacers. Don't think I would be comfortable with that.
« Reply #2 on: December 16, 2017, 05:38:56 PM »
That's why they make lotsa washers - so you can just stack 'em tall enough to take up the desired amount of slack. :cheers: :cheers: :roll:
« Reply #3 on: December 16, 2017, 05:39:30 PM »
    What thickness did you use?
« Reply #4 on: December 16, 2017, 05:41:42 PM »
That's why they make mlotsa washers - so you can just stack 'em tall enough to take up the desired amount of slack. :cheers: :cheers: :roll:
 Sorta what Im doing now Slim to get some clearance  :cheers:
« Reply #5 on: December 16, 2017, 06:04:00 PM »
We've gone over 200 and set records with 3/4-inch spacers -- for the same reason you want to use them.
Offline Skip Pipes
  • I hate being bipolar, its awesome!
« Reply #6 on: December 16, 2017, 07:48:34 PM »
I run steel spacers on the rear axle of my Roadster, over 200 mph, no issues.
Skip Pipes
Skip's Garage
Offline Dynoroom
« Reply #7 on: December 17, 2017, 02:14:28 AM »
If you don't see a rule don't envision one.  :wink:
« Reply #8 on: December 17, 2017, 03:09:15 PM »
Thanks to everyone for your guidance and experience all this information will save me A lot of lost time and grief.
 Merry Christmas and Happy New Year to you all.
 Ronnieroadster
